I am not really sure what section to put this under, but I just picked this one. Anyways, I am working on a project for my brothers and want to play some Pong with them, but I don't really how on a Dot Matrix from [this kit].((https://www.amazon.com/EL-KIT-008-Project-Complete-Ultimate-TUTORIAL/dp/B01EWNUUUA/ref=sr_1_1_sspa?dchild=1&keywords=arduino%20mega%20kit&qid=1626207537&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExR1NEMVNXUkpRS0ZDJmVuY3J5cHRlZElkPUEwODgxNjc5MzA2V1U5RFFLVEpBSSZlbmNyeXB0ZWRBZElkPUEwNTQyNzgzMllKVEdLM0pFNURRViZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=)). I had an idea: to use the map function. I don't really know how to implement this with the Dot Matrix. I have an Arduino Mega along with two potentiometers to accompany my project. All help will be appreciated. Thanks, Austin.
#include <LedControl.h>
int DIN = 10;
int CS = 11;
int CLK = 12;
const int playerOnePin = A0;
const int playerTwoPin = A1;
int playerOneValue;
int playerOneValue2;
int playerTwoValue;
int playerTwoValue2;
LedControl lc = LedControl(DIN, CLK, CS, 0);
lc.shutdown(0, false); //The MAX72XX is in power-saving mode on startup
lc.setIntensity(0, 15); // Set the brightness to maximum value
lc.clearDisplay(0); // and clear the display
pinMode(playerOnePin, INPUT);
pinMode(playerTwoPin, INPUT);
readPot();
movePaddle();
defaultPaddle();
void defaultPaddle() {
byte a[8] = {0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
if (playerOneValue2 == 0) {
printByte(a);
void printByte(byte character []) {
int i = 0;
for (i = 0; i < 8; i++)
lc.setRow(0, i, character[i]);
void readPot() {
playerOneValue = analogRead(A0);
playerOneValue2 = map(playerOneValue, 0, 1023, 0, 7);
Serial.println(playerOneValue2);
void movePaddle() {
if (playerOneValue2 == 1) {
displayNewPaddle();
void displayNewPaddle() {
byte a2[8] = {0x00, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,};
int DIN = 10;
int CS = 11;
int CLK = 12;
byte displayImage[8] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
// considering a 2d co-ordinate system with origin (0,0) at bottom left corner
int ballX = 3; //X position
int ballY = 7; //Y position - top
int speedX = 0; // no X movement, can be -1, 0 or 1
int speedY = -1; // downward Y movement, can be -1, 0 or 1
int paddleX = 4; // X position of center of paddle - can be 1 to 6. Paddle width is 3
int score = 0;
pinMode (A0, INPUT);
pinMode (A1, INPUT);
lc.shutdown(0, false); // Keep MAX72XX awake
// update ball position
ballX = ballX + speedX;
ballY = ballY + speedY;
// check for ball interaction with walls
if (ballX == 0 || ballX == 7) {
speedX = speedX * -1; // bouncing off walls in horizontal direction
// bouncing off ceiling
if (ballY == 7) {
speedY = speedY * -1; // bouncing off the ceiling
// bouncing off the paddle
if (ballY == 0 && ballX >= (paddleX - 1) && ballX <= (paddleX + 1)) {
score++; // player earns a point
// going past the paddle
if (ballY == 0 && ballX < (paddleX - 1) && ballX > (paddleX + 1)) {
// going past the paddle - player is out
Serial.println(); Serial.print("Score: "); Serial.println(score);
for (int i = 0; i < 8; i++) {
displayImage[i] = 0x00;
displayImage[3] = 0xFF; displayImage[4] = 0xFF; // show a line
renderByte(displayImage);
while (1); // Freeze
// clearing the image variable
// generating new image
addPixel(ballX, ballY); // adding the ball position to image
addPixel(paddleX - 1, 0); addPixel(paddleX, 0); addPixel(paddleX + 1, 0);
// adding paddle position to image
renderByte(displayImage); // show the generated image
// handling paddle control
if (analogRead(A0) && paddleX > 0) {
paddleX = paddleX - 1; // move paddle left
if (analogRead(A1) && paddleX < 7) {
paddleX = paddleX + 1; // move paddle right
delay(200);
void addPixel(int xVal, int yVal) {
int newRowval = 2 ^ (7 - xVal);
int rowVal = displayImage[7 - yVal];
displayImage[7 - yVal] = rowVal || newRowval; // inserting a 1 at the required pixel
void renderByte(byte image [])
int i = 0;
lc.setRow(0, i, image[i]);
