Arduino Port Manipulation Reference mistyping?
Hope this is the right place for this...
I am looking at the reference page for port manipulation
and I am pretty sure within the example, PORTB, and PINB are meant to PORTD and PIND. I have highlighted the errors in red.
Referring to the pin map above, the PortD registers control Arduino digital pins 0 to 7.
You should note, however, that pins 0 & 1 are used for serial communications for programming and debugging the Arduino, so changing these pins should usually be avoided unless needed for serial input or output functions. Be aware that this can interfere with program download or debugging.
DDRD is the direction register for Port D (Arduino digital pins 0-7). The bits in this register control whether the pins in PORTD are configured as inputs or outputs so, for example:
DDRD = B11111110; // sets Arduino pins 1 to 7 as outputs, pin 0 as input
DDRD = DDRD | B11111100; // this is safer as it sets pins 2 to 7 as outputs
// without changing the value of pins 0 & 1, which are RX & TX
//See the bitwise operators reference pages and The Bitmath Tutorial in the Playground
PORTB is the register for the state of the outputs. For example;
PORTD = B10101000; // sets digital pins 7,5,3 HIGH
You will only see 5 volts on these pins however if the pins have been set as outputs using the DDRD register or with pinMode().
PINB is the input register variable It will read all of the digital input pins at the same time
or am I missing something?
Bug reported submitted: Confusing / inaccurate examples in "Port Registers" documentation · Issue #2684 · arduino/Arduino · GitHub
