After placing the DHTlib file and LiquidCrystal_i2C files into the library folder in Arduino IDE 1.0.6
The problem is that i can't seem to fix this error.
In file included from sketch_oct29a.ino:3:
C:\Users\Jaydon\Desktop\Arduino\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:80: error: conflicting return type specified for 'virtual void LiquidCrystal_I2C::write(uint8_t)'
C:\Users\Jaydon\Desktop\Arduino\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'
I've tried replacing the Liquidcrystal_I2C library from different sources online but none of them seem to work.
@dannable Awesome! I replaced the LCD Library with DFRobot's version and its compiling now. Lucky to have your help dannable, wouldn't know what to do without you! :'D
If you are using the FMalpartida LiquidCrystal I2C lib... Follow the instructions in the download...
It replaces the code in the IDE library/LiquidCrystal folder.
C:\Program Files (x86)\Arduino105\libraries\LiquidCrystal
and replaces the original somewhat clunky code with a much better and more universal library as it does all that LiquidCrystal does and adds I2C too...
