Arduino Portenta H7 - MQTT using Crypto Chips(SE050, ATECC608) for SSL/TLS authentication
I am excited that I finally got my Arduino Portenta H7 and I am new to its functionalities. I would like to explore more on Portenta H7 crypto chips(SE050, ATECC608) :lock:
I am trying to connect my own local MQTT broker using certificate for SSL/TLS authentication. However, I could not find any example especially for Portenta H7.
I am trying to follow some examples for different Arduino MKR Board Family as listed below:
But, seem like ECCX08 library is not compatible with Portenta H7.
I would like to ask help Arduino Community whether anyone has worked with Portenta H7 and its crypto chips. Any advice or examples greatly appreciated :pray: Thanks
We have been successul in getting messages back on forth using the
Portenta_H7_AsynchWebServer library
There are MQTT examples when the library is loaded, and they work with Mosquitto as a broker
@thein_artc are you sure the ECCX08 library is not supported? Because I am using the same sketch and the only issue im facing is with connecting to the broker. The ECCX08 library works perfectly.
