Arduino POV analog clock
I want to make a analog pov clock using arsuino. I need help with the code. I am using 3 74hc595 shift register to connect 24 led. Plz help with the code.
(deleted)
//Propeller clock2
//digitalClock.ino
#include <Wire.h>
#include <Rtc_Pcf8563.h>
Rtc_Pcf8563 rtc;
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
int delayVar = 400;
const byte BUTTON = 2;
volatile int r=0;
// interrupt handler...
void pinChange ()
  r=1;
  pinMode(latchPin, OUTPUT);
  digitalWrite (BUTTON,HIGH);
  attachInterrupt (0, pinChange,RISING);
  rtc.initClock();
  //set a time to start with.
  //day, weekday, month, century, year
  rtc.setDate(20, 6, 1, 0, 14);
  //hr, min, sec
  rtc.setTime(8, 35, 40);
//Serial.begin(9600);
 if(r==1){
numWrite(12);
numWrite(12);
second();
numWrite(11);
minute();
numWrite(11);
hour();
delay(14);
day();
numIWrite(11);
month();
numIWrite(11);
year();
r=0;
rtc.formatTime();
rtc.formatDate();
void shiftOut(int myDataPin, int myClockPin, byte myDataOut) {
  int i=0;
  int pinState;
  pinMode(myClockPin, OUTPUT);
  pinMode(myDataPin, OUTPUT);
  digitalWrite(myDataPin, 0);
  digitalWrite(myClockPin, 0);
  for (i=7; i>=0; i--)  {
    if ( myDataOut & (1<<i) ) {
      pinState= 1;
    else {
      pinState= 0;
    digitalWrite(myDataPin, pinState);
    digitalWrite(myClockPin, 1);
// Function to write numbers
void numWrite(int alp)
int AL=alp;
switch(AL)
case 1:
ledWrite(0);
delayMicroseconds(delayVar);
ledWrite(128);
ledWrite(254);
ledWrite(132);
ledWrite(0);
ledWrite(0);
case 2:
ledWrite(140);
ledWrite(146);
ledWrite(146);
ledWrite(146);
ledWrite(98);
ledWrite(0);
case 3:
ledWrite(198);
ledWrite(170);
ledWrite(146);
ledWrite(130);
ledWrite(130);
ledWrite(0);
case 4:
ledWrite(254);
ledWrite(16);
ledWrite(16);
ledWrite(16);
ledWrite(30);
ledWrite(0);
case 5:
ledWrite(98);
ledWrite(146);
ledWrite(146);
ledWrite(146);
ledWrite(140);
ledWrite(0);
case 6:
ledWrite(98);
ledWrite(146);
ledWrite(146);
ledWrite(146);
ledWrite(124);
ledWrite(0);
case 7:
ledWrite(16);
ledWrite(254);
ledWrite(18);
ledWrite(2);
ledWrite(2);
ledWrite(0);
case 8:
ledWrite(108);
ledWrite(146);
ledWrite(146);
ledWrite(146);
ledWrite(108);
ledWrite(0);
case 9:
ledWrite(124);
ledWrite(146);
ledWrite(146);
ledWrite(146);
ledWrite(140);
ledWrite(0);
case 0:
ledWrite(124);
ledWrite(130);
ledWrite(130);
ledWrite(130);
ledWrite(124);
ledWrite(0);
case 11:
ledWrite(0);
 ledWrite(108);
 ledWrite(0);
 delay(2);
default:
ledWrite(0);
void ledWrite(int var)
int data = var;
digitalWrite(latchPin, 0);
    shiftOut(dataPin, clockPin,data);
   shiftOut(dataPin, clockPin,0);
    digitalWrite(latchPin,1);
void second()
  int sec= rtc.getSecond();
  int sec1 = sec/10;
  int sec2 = sec%10;
  numWrite(sec2);
  numWrite(sec1);
void minute()
  int minn= rtc.getMinute();
  int min1 = minn/10;
  int min2 = minn%10;
  numWrite(min2);
  numWrite(min1);
void hour()
  int hor= rtc.getHour();
  int hor1 = hor/10;
  int hor2 = hor%10;
  numWrite(hor2);
  numWrite(hor1);
void numIWrite(int alp)
int AL=alp;
switch(AL)
case 1:
//int b[]={9,31,1};
ledWrite(9);
ledWrite(31);
ledWrite(1);
ledWrite(0);
case 2:
ledWrite(23);
ledWrite(21);
ledWrite(29);
ledWrite(0);
case 3:
ledWrite(17);
ledWrite(21);
ledWrite(31);
ledWrite(0);
case 4:
ledWrite(28);
ledWrite(4);
ledWrite(31);
ledWrite(0);
case 5:
ledWrite(29);
ledWrite(21);
ledWrite(23);
ledWrite(0);
case 6:
ledWrite(31);
ledWrite(21);
ledWrite(23);
ledWrite(0);
case 7:
ledWrite(16);
ledWrite(16);
ledWrite(31);
ledWrite(0);
case 8:
ledWrite(31);
ledWrite(21);
ledWrite(31);
ledWrite(0);
case 9:
ledWrite(29);
ledWrite(21);
ledWrite(31);
ledWrite(0);
case 0:
ledWrite(31);
ledWrite(17);
ledWrite(31);
ledWrite(0);
case 11:
ledWrite(4);
ledWrite(4);
ledWrite(0);
default:
ledWrite(0);
void month()
  int k = rtc.getMonth();
  int k1=k/10;
  numIWrite(k1);
  k1 = k%10;
  numIWrite(k1);
void day()
  int k= rtc.getDay();
  int k1=k/10;
  numIWrite(k1);
  k1 = k%10;
  numIWrite(k1);
void year()
  numIWrite(2);
  numIWrite(0);
int k =rtc.getYear();
 k =k%2000;
int k1 = k/10;
numIWrite(k1);
k1= k%10;
numIWrite(k1);
Thanx bill. I have seen that site but it didint have code for analog clock. Thanx a lot for your help. I jst needed a reference. Thanx for your code.. :slight_smile:
Hey bill i wanted code for analog clock not digital
You just need a reference, be it analog or digital clock is about the same for POV.
#include <TimerOne.h>
Analog Clock
Paul Cox Dec 2010
#define    PI      3.141592653589793e-06;
byte rows[8] = {9, 14, 8, 12, 1, 7, 2, 5};
byte cols[8] = {13, 3, 4, 10, 6, 11, 15, 16};
byte pins[16] = {5, 4, 3, 2, 14, 15, 16, 17, 13, 12, 11, 10, 9, 8, 7, 6};
byte screen[8] = {0, 0, 0, 0, 0, 0, 0, 0};
volatile byte screenRow = 0;
volatile byte screenCol = 0;
int iHour = 0;
int iMin = 0;
int iSec = 0;
	Timer1.initialize(100);
	for (int i = 2; i <= 17; i++)
		pinMode(i, OUTPUT);
	Timer1.attachInterrupt(doubleBuffer);
	resetAnim();
void doubleBuffer()
	digitalWrite(translatePin(rows[screenRow]), LOW);
	digitalWrite(translatePin(cols[screenCol]), HIGH);
	screenCol++;
	if (screenCol >= 8)
		screenCol = 0;
		screenRow++;
		if (screenRow >= 8)
			screenRow = 0;
	if((screen[screenRow] >> screenCol) & B1 == B1)
		digitalWrite(translatePin(rows[screenRow]), HIGH);
		digitalWrite(translatePin(cols[screenCol]), LOW);
byte translatePin(byte original)
	return pins[original - 1];
void allOFF()
	for (int i = 0; i < 8; i++)
		screen[i] = 0;
void on(byte row, byte column)
	screen[column-1] |= (B1 << (row - 1));
void off(byte row, byte column)
	screen[column-1] &= ~(B1 << (row - 1));
void resetAnim()
		screen[i] = B11111111;
		delay(25);
		screen[i] = B00000000;
		delay(25);
	drawClock();
	iSec++;
	if (iSec == 60)
		iSec = 1;
		iMin++;
		if (iMin == 60)
			iMin = 0;
			iHour++;
			if (iHour == 12)
				iHour = 0;
	delay(10);
void drawClock()
	allOFF();
	setHand(iHour,12,3);
	setHand(iMin,60,4);
	setHand(iSec,60,5);
// work out the pixel for a hand - val is out of a possible max val
// radius is distance from the centre
void setHand(int iVal, int iMax, int iRadius)
	double  dAngle = (iVal * 2 * PI) / iMax;
	double  dPosX = 4.5 + (iRadius * cos(dAngle));
	double  dPosY = 4.5 + (iRadius * sin(dAngle));
	drawLine(5,5,constrain(round(dPosX),1,8),constrain(round(dPosY),1,8));
void drawLine(int x0, int y0, int x1, int y1)
	int      iTemp;
	boolean  bSteep = abs(y1 - y0) > abs(x1 - x0);
	if (bSteep)
		iTemp = x0; x0 = y0; y0 = iTemp;    // swap x0,y0
		iTemp = x1; x1 = y1; y1 = iTemp;    // swap x1,y1
	if (x0 > x1)
		iTemp = x0; x0 = x1; x1 = iTemp;    // swap x0,x1
		iTemp = y1; y1 = y0; y0 = iTemp;    // swap y0,y1
	int deltax = x1 - x0;
	int deltay = abs(y1 - y0);
	int error = deltax / 2;
	int ystep = ((y0 < y1) ? 1 : -1);
	int y = y0;
	int x = x0;
	while(x <= x1)
		if (bSteep)
			on(y,x);
			on(x,y);
		error = error - deltay;
		if (error < 0)
			y = y + ystep;
			error = error + deltax;
		x++;
HD_POV.pde (17.4 KB)
