Hello i am using custom board and i have three lines. VBUS, VBAT & VSYS. How should i use the switch combination in order to selectively use the lines. The description of the lines are as below:
- V-BUS : 5 volt supply from USB.
- V-BATT : Voltage supply from battery.
- VSYS : Regulated 3.3 volt to complete system. This is generated from V-BATT and V-BUS both.
I have made a truth table with all possible combinations and i want to get condition no 4,6 & 7. Rest other conditions are not required. The truth table is attached below:
