Arduino Power Questions
Hello everyone, I have Arduino Power Questions. If I put 6v to VIN and gnd to gnd will the 5V pin output 5V exactly? if not, how much volts should i connect to vin???
As you have not said I am going to assume that you have a Uno or an equivalent
From Arduino Uno Rev3 — Arduino Online Shop
The board can operate on an external supply from 6 to 20 volts. If supplied with less than 7V, however, the 5V pin may supply less than five volts and the board may become unstable. If using more than 12V, the voltage regulator may overheat and damage the board. The recommended range is 7 to 12 volts.
Thanks a lot for the information you provided, and yes am using an arduino uno.
