So I just purchased a 2001 Miata and my first project is to wire in an aux input to the car's stock radio. Although an aftermarket radio would be easier, I'd much prefer to spend less, learn some things about the Arduino platform, and not give anybody a reason to break into my car.
So my car's main head unit has a CD player and an AM/FM radio tuner. A dealer option for my car was a cassette deck which connects to the main head unit via a proprietary cable. This cable includes power, L/R audio signals, and some control signals for the main head unit and cassette player to talk to each other. The important lines are listed below:
| Pin | Description |
| 1 | Right Input |
| 2 | Signal Ground |
| 3 | Left Input |
| 4 | Combi Control - Pulled high when radio/CD is playing. Pulled low when line input (cassette) is active. If line input is active when the head unit turns off, a high/low pulse is sent from the main head unit to the cassette deck to turn the cassette deck off. |
| 5 | Aux Control Output - The main head unit remembers if the line input (cassette) was active when it was last shut off. When the main head unit is powered on, it will send out a pulse to turn the line input on. |
| 6 | Aux Control Input - Cassette deck sets this high so the main head unit switches its source to cassette (and turn on if it was turned off). If pulled low, the main head unit shuts off (unless pin 4 is high). |
| 9 | Power Supply ACC - Outputs 12V which goes on and off with the ignition switch. Cassette deck draws 320uA from this pin at all times when the ignition is on. This pin only allows a very small current without dropping voltage because of a 1K resistor built into the main head unit. |
| 10 | Ground |
| 11 | Power +B - Supplies a constant 12V no matter whether the ignition is on or off. The cassette deck draws 0.2A from this pin when playing. |
So it doesn't look like a big deal. I just need the Arduino to read/control 3 DIOs for Pins 4-6 and another DIO for an external button to turn the line input on/off. The problem is power. Ideally, I'd like to use pin 9 for power since it will shut off once the car turns off. Can I just hook up an LM7805 voltage regulator to convert 12V down to 5V to power an Arduino Board Pro Mini: http://arduino.cc/en/Main/ArduinoBoardProMini? According to the specs, active power consumption for this board is ~250uA which is less than the 320uA the cassette deck uses. Will the power regulator work with such a low draw board? Will the regulator draw any additional current which would put it over the 320uA max? I don't have much experience with circuits outside of basic I/O.
Am I missing any other problems with this design?
Thanks
Sources:
Similar Radio Project: Aux Input: Control Circuit To Switch Line Input - MX-5 Miata Forum
Cassette Connector Pinout: http://miata.fosketts.net/index.php?title=CN200
LM7805: Intelligent Power and Sensing Technologies | onsemi
Arduino Pro Mini: http://arduino.cc/en/Main/ArduinoBoardProMini
