Arduino Powering
Hi.
First of all sorry for my bad english.
I am here for a question about powering my arduino uno. I am working on a project where i am powering a lot of logical devices and they all are driven by an LM7805 witch gives me an output voltage of 5V.
Now the print layout is allready done and now i noticed that i need to power the arduino on the Vin Pin with more then 7 volts, wich would destroy my current project pretty much because its all done allready and i put in a lot of work.
However, after looking at the shematic, if i have an allready regulated 5V, could i just attach it to the 5V output pin? Shouldnt it work because the 5v pin is set directly after the arduino uno onboard regulator?
I would be very thankfull for an answer.
Regards
Topi
Yes, u can power with a 5V regulated supply direct the 5V and GND pins.
Hi Topi,
Welcome; I’ve lived in several countries where I did not understand much of the Chinese/French/Arabic etc :slight_smile:
See more information HERE:
See the UNO schematic Diagram HERE:
And Power Considerations HERE:
You should be OK with 5V regulated to the “5V” UNO pin.
Great. I read about the voltage drop if you attach 5V to the Vin. With that I would have my other devices not recognizing the logical high signal from the I/O-Pins because it would be lower.
That caused me a lot of trouble.
Thank you for the help, I will attach the GND and Vout from my LM7805 directly to 5V and GND pins.
One last question: the GND Pins are connected right? so i dont need to connect the "LM7805-GND" to both arduino gnd pins? One of the three aviable should be enough right?
Thank you guys very much.
Yes, u need only connect to one GND pin - they are all common.
