arduino ppm signal
Hello i'm trying to send ppm signal with the pin 10 of the arduino to a Scherrer UHM tx radio, on the receiver, a servo motor is connected but the servo doesn't move. An idea ? Thank you.
I’ve found this code on github, I think it works and the radio module are correctly binded…
//this programm will put out a PPM signal
//////////////////////CONFIGURATION///////////////////////////////
#define chanel_number 8 //set the number of chanels
#define default_servo_value 1500 //set the default servo value
#define PPM_FrLen 22500 //set the PPM frame length in microseconds (1ms = 1000µs)
#define PPM_PulseLen 300 //set the pulse length
#define onState 1 //set polarity of the pulses: 1 is positive, 0 is negative
#define sigPin 10 //set PPM signal output pin on the arduino
/this array holds the servo values for the ppm signal
change theese values in your code (usually servo values move between 1000 and 2000)
int ppm[chanel_number];
void setup(){
//initiallize default ppm values
for(int i=0; i<chanel_number; i++){
ppm*= default_servo_value;*
  • pinMode(sigPin, OUTPUT);*
  • digitalWrite(sigPin, !onState); //set the PPM signal pin to the default state (off)*
  • cli();*
  • TCCR1A = 0; // set entire TCCR1 register to 0*
  • TCCR1B = 0;*
  • OCR1A = 100; // compare match register, change this*
  • TCCR1B |= (1 << WGM12); // turn on CTC mode*
  • TCCR1B |= (1 << CS11); // 8 prescaler: 0,5 microseconds at 16mhz*
  • TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt*
  • sei();*
    void loop(){
  • //put main code here*
  • static int val = 1;*
  • ppm[0] = ppm[0] + val;*
  • if(ppm[0] >= 2000){ val = -1; }*
  • if(ppm[0] <= 1000){ val = 1; }*
  • delay(10);*
    ISR(TIMER1_COMPA_vect){ //leave this alone
  • static boolean state = true;*
  • TCNT1 = 0;*
  • if(state) { //start pulse*
  • digitalWrite(sigPin, onState);*
    OCR1A = PPM_PulseLen * 2;
  • state = false;*
  • else{ //end pulse and calculate when to start the next pulse*
  • static byte cur_chan_numb;*
  • static unsigned int calc_rest;*
  • digitalWrite(sigPin, !onState);*
  • state = true;*
  • if(cur_chan_numb >= chanel_number){*
  • cur_chan_numb = 0;*
  • calc_rest = calc_rest + PPM_PulseLen;//*
    OCR1A = (PPM_FrLen - calc_rest) * 2;
  • calc_rest = 0;*
  • else{*
    OCR1A = (ppm[cur_chan_numb] - PPM_PulseLen) * 2;
  • calc_rest = calc_rest + ppm[cur_chan_numb];*
  • cur_chan_numb++;*
