Ciao a tutti sto utilizzando un arduino uno e un ethernet shield.
Ho creato tramite raspberry pi un server virtuale dove risiede il mio sito.
L’unico problema è che non riesco a far comunicare i due.
Dal web genero dei valori che dovranno essere inviati ad arduino, Quindi genero tramite il metodo get un url es.192.168.1.140/action.php?uno=10&due=30&tre=40.
Come faccio a dire ad arduino di selezionarmi i valori di ogni variabile?
Ho cercato in internet e ho visto l’esempio del webclient ma non capisco come fare.
Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe, based on work by Adrian McEwen
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server[] = "www.google.com"; // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 0, 177);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET /search?q=arduino HTTP/1.1");
client.println("Host: www.google.com");
client.println("Connection: close");
client.println();
// if you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
while (true);
