Bitte zeichne ein Verdrahtungsschema (oder mach ein Foto) von Deinem Setup. Poste den Sketch und Links zur verwendeten Hardware sowie den Bibliotheken.
// Arduino interface for the use of ws2812 operated LEDs
// Uses Adalight protocol and is compatible with Boblight, Prismatik etc
// "Magic Word" for synchronisation is 'Ada' followed by LED High, Low and Checksum
///// User definitions /////
#include "FastLED.h"
// Define the number of LEDs
#define NUM_LEDS 130
// Define SPI Pin
#define PIN 6
// Baudrate, higher rate allows faster refresh rate and more LEDs (defined in /etc/boblight.conf)
#define serialRate 115200
//// End of user definitions /////
// Utilises FastSPI_LED2
#define FORCE_SOFTWARE_SPI
#define FORCE_SOFTWARE_PINS
// Adalight sends a "Magic Word" (defined in /etc/boblight.conf) before sending the pixel data
uint8_t prefix[] = {'A', 'd', 'a'}, hi, lo, chk, i;
// initialise LED-array
CRGB leds[NUM_LEDS];
FastLED.addLeds<WS2812, PIN, RGB>(leds, NUM_LEDS);
// initial RGB flash
LEDS.showColor(CRGB(255, 0, 0));
LEDS.showColor(CRGB(0, 255, 0));
LEDS.showColor(CRGB(0, 0, 255));
LEDS.showColor(CRGB(0, 0, 0));
Serial.begin(serialRate);
Serial.print("Ada\n"); // Send "Magic Word" string to host
// wait for first byte of Magic Word
for(i = 0; i < sizeof prefix; ++i) {
waitLoop: while (!Serial.available()) ;;
// Check next byte in Magic Word
if(prefix[i] == Serial.read()) continue;
// otherwise, start over
i = 0;
goto waitLoop;
// Hi, Lo, Checksum
hi=Serial.read();
lo=Serial.read();
chk=Serial.read();
// if checksum does not match go back to wait
if (chk != (hi ^ lo ^ 0x55))
i=0;
goto waitLoop;
memset(leds, 0, NUM_LEDS * sizeof(struct CRGB));
// read the transmission data and set LED values
for (uint8_t i = 0; i < NUM_LEDS; i++) {
byte r, g, b;
while(!Serial.available());
r = Serial.read();
g = Serial.read();
b = Serial.read();
leds[i].r = r;
leds[i].g = g;
leds[i].b = b;
// shows new values
FastLED.show();
Hallo, mir geht´s ähnlich wie dem Topicstarter, weder mit dem Sketch aus dem Link, noch dem verbesserten funktioniert es bei mir.
Der Arduino bekommt Daten, was man am blinkenden RX erkennt, aber alles bleibt dunkel.
Vlt. liegt es auch an meiner boblight.conf.
