Arduino pro 5v 328 strange problem
Hi, I have a sketch that work in a duemilanove board with ATmega8 and works fine, after I upload to a arduino Pro doesn,t work anymore.
ok, my project is about voice controlled device, and if it works just fine with duemilanove should work with arduino pro, right?
to test the arduino I've used something similar to "Blink" example pontificated to blink on all pins, and it does just fine.
so why is not working if I use the same voice module on both?
thanks in advice
It is line 32 in the code that is wrong and the red wire is going to the wrong place.
What sort of answer do you expect from the information you have given?
