Hello,
I made a sketch with the DCC library (model trains). I developed on the Uno because that's easier with the pin headers.
But after transferring the working sketch to the Arduino Pro Micro 16 MHz (on my PCB), it doesn't work. Even the example monitor sketch (to monitor every DCC signal) doesn't work on it.
I read somewhere on the forum about the missing Timer 2, I don't know of that's the problem.
Library:
Sketch:
#include <TimedAction.h>
#include <NmraDcc.h>
#define GO 15
#define STOP A0
#define STATUS A1
* Trainduino *
*--------> DCCSWITCHCONTROLLER <---------*
* V 0.7 PRERELEASE *
THIS IS A PRERELEASE! I'm never resposibly for any damage to your stuff! This version is NOT tested.
(c) Dylan Van Assche (2013 - 2014), producer of the Trainduino serie.
GROUP DEFINITION:
0 = DCC Locdecoders
100 = DCC Switch Controllers
200 = DCC Scenery Controllers
300 = DCC Special Controllers
Controller:
GROUP: 100
Number: 001
Adres: 101 - 106
NmraDcc Dcc ;
DCC_MSG Packet ;
const int NumberOfOutputs = 10;
const int DccAckPin = 3 ;
int Output[] = {3, 4, 5, 6, 7, 8, 9, 10, 16, 14}; // Arduino Pro Micro, Arduino MEGA
// int Output[] = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12}; // Arduino Uno, Arduino Leonardo, Arduino Mini
boolean RouteStatus = false;
unsigned long OutputpreviousMillis = 0;
int OutputNumber = 0;
int RoutePhase = 1;
TimedAction RouteTimer = TimedAction(200, RouteFunction);
struct CVPair
uint16_t CV;
uint8_t Value;
CVPair FactoryDefaultCVs [] =
{CV_ACCESSORY_DECODER_ADDRESS_LSB, 1},
{CV_ACCESSORY_DECODER_ADDRESS_MSB, 0},
uint8_t FactoryDefaultCVIndex = 0;
Serial.println("DCC Switch Controller V0.1");
// Setup DCC
pinMode( DccAckPin, OUTPUT );
Dcc.pin(0, 2, 1);
Dcc.init( MAN_ID_DIY, 10, FLAGS_OUTPUT_ADDRESS_MODE | FLAGS_DCC_ACCESSORY_DECODER, 0 );
for (int i = 0; i < NumberOfOutputs; i++)
pinMode(Output[i], OUTPUT);
pinMode(STOP, OUTPUT); // STOP
pinMode(GO, OUTPUT); // GO
pinMode(STATUS, OUTPUT); // STATUS
Dcc.process();
if ( FactoryDefaultCVIndex && Dcc.isSetCVReady())
FactoryDefaultCVIndex--; // Decrement first as initially it is the size of the array
Dcc.setCV( FactoryDefaultCVs[FactoryDefaultCVIndex].CV, FactoryDefaultCVs[FactoryDefaultCVIndex].Value);
if (RouteStatus == true)
RouteTimer.check(); // Delay between 2 actions in the route.
digitalWrite(GO, HIGH);
digitalWrite(STOP, LOW);
digitalWrite(GO, LOW);
digitalWrite(STOP, HIGH);
void notifyCVAck(void)
digitalWrite( DccAckPin, HIGH );
delay( 6 );
digitalWrite( DccAckPin, LOW );
void notifyCVResetFactoryDefault()
FactoryDefaultCVIndex = sizeof(FactoryDefaultCVs) / sizeof(CVPair);
// This function is called whenever a normal DCC Turnout Packet is received
void notifyDccAccState( uint16_t Addr, uint16_t BoardAddr, uint8_t OutputAddr, uint8_t State)
switch (Addr)
case 101: // Switch 1
if ((OutputAddr % 2) == 0)
if(State == 8)
digitalWrite(Output[4], HIGH);
digitalWrite(STATUS, HIGH);
digitalWrite(Output[4], LOW);
digitalWrite(STATUS, LOW);
if(State == 8)
digitalWrite(Output[5], HIGH);
digitalWrite(Output[5], LOW);
case 102: // Switch 2
if(State == 8)
digitalWrite(Output[6], HIGH);
digitalWrite(Output[6], LOW);
if(State == 8)
digitalWrite(Output[7], HIGH);
digitalWrite(Output[7], LOW);
case 103: // Brake module
if(State == 8)
digitalWrite(Output[8], HIGH);
digitalWrite(Output[8], LOW);
if(State == 8)
digitalWrite(Output[9], HIGH);
digitalWrite(Output[9], LOW);
case 104: // Signal address 1
digitalWrite(Output[0], HIGH); // STOP (RED)
digitalWrite(Output[1], LOW);
digitalWrite(Output[2], LOW);
digitalWrite(Output[3], LOW);
if(State == 8)
digitalWrite(Output[0], LOW); // GO (GREEN)
digitalWrite(Output[1], HIGH);
if(State == 8)
case 105: // Signal address 2
digitalWrite(Output[2], HIGH); // HALF-SPEED (DOUBLE YELLOW)
digitalWrite(Output[3], HIGH);
if(State == 8)
digitalWrite(Output[2], HIGH); // HALF-SPEED + GO (YELLOW + GREEN);
if(State == 8)
case 106: // Route
RouteStatus = true;
if(State == 8)
void RouteFunction() // Delay between GO and STOP: X * 250ms. 7,5 seconds: 30x 250ms. The STOP command has number 31, 32, 33, ...
switch (RoutePhase)
case 1: // 1st action: Set switches
RoutePhase++;
case 2:
RoutePhase++;
case 3: // 2nd action: Set Brake module & signal
digitalWrite(Output[0], HIGH); // GO (GREEN)
RoutePhase++;
case 4:
RoutePhase++;
case 35: // 3rd action: Set Brake module & signal BACK to previous state
digitalWrite(Output[0], LOW); // STOP (RED)
RoutePhase++;
case 36:
RoutePhase++;
case 37: // 4th action: Set switches BACK to previous state
RoutePhase++;
case 38:
RoutePhase = 1;
default:
RoutePhase++;
Cheers,
Dylan
