Arduino pro micro connect gsm 800l and rcwl 0516
I want when the rcwl 0516 detects movement the gsm 800l module makes a call to the number. The sensors are working properly but when I load the code the call is not made. The voltage is supplied accordingly.
t#include <SoftwareSerial.h>
// Define software serial port for SIM800L communication
SoftwareSerial gsmSerial(10, 11);  // RX, TX (use appropriate pins for your setup)
// Pin connected to RCWL-0516 OUT pin
const int motionSensorPin = 2;
// Phone number to call
const String phoneNumber = "+995505052";
// Variable to keep track of motion detection state
bool motionDetected = false;
// Variable to keep track of the last motion detection time
unsigned long lastMotionTime = 0;
// Delay between motion detection and making a call (e.g., 5 seconds)
const unsigned long motionToCallDelay = 5000;
// Delay between calls (e.g., 30 seconds)
const unsigned long callDelay = 30000;
// Flag to indicate if a call is in progress
bool callInProgress = false;
  // Initialize Serial for debugging
  // Initialize software serial for GSM module
  gsmSerial.begin(9600);
  // Set motion sensor pin as input
  pinMode(motionSensorPin, INPUT);
  Serial.println("Setup complete.");
  // Check if motion is detected
  if (digitalRead(motionSensorPin) == LOW) {
    if (!motionDetected) {
      Serial.println("Motion detected!");
      motionDetected = true;
      lastMotionTime = millis();
  // Check if enough time has passed since motion was detected
  if (motionDetected && (millis() - lastMotionTime >= motionToCallDelay) && !callInProgress) {
    makePhoneCall();
  delay(100);  // Short delay to avoid bouncing issues
void makePhoneCall() {
  Serial.println("Dialing number...");
  gsmSerial.println("ATD" + phoneNumber + ";");
  // Increased delay to ensure the command is sent and processed
  delay(5000);
  // Read the GSM module response
  while (gsmSerial.available()) {
    char c = gsmSerial.read();
    Serial.write(c);
  Serial.println("In call...");
  callInProgress = true;
  delay(20000);  // Adjust this delay based on the desired call duration
  Serial.println("Hanging up...");
  gsmSerial.println("ATH");
I can not help you with your problem.
Why? The Pro Micro has a free UART on the Tx/Rx pins; use that instead of SoftwareSerial.
how do you power the gsm 800l module?
when transmitting it can take a couple of amps which could overload the pro micro
It blinks once every 3 seconds and as I heard it should blink once every 9 seconds to work properly. I supply the correct voltage but it still flashes once every 3 seconds
When I test only the gsm 800l module, it makes a call, but no matter what result I want to get, when I load the code, it no longer calls the number.
