Hello friends, I have made a midi keyboard using arduino nano with the help of Grumpy_Mike. Now I want to make it using pro micro so my PC will recognize it as USB-MIDI device, what changes I should make in the code to use USBMIDI library?`
#include <MIDI.h>
#include <Keypad.h>
const byte ROWS = 9; //six rows
const byte COLS = 6; //nine columns
char keys[COLS][ROWS] = {
{48, 49, 50, 51, 52, 53, 54, 55, 56},
{57, 58, 59, 60, 61, 62, 63, 64, 65},
{66, 67, 68, 69, 70, 71, 72, 73, 74},
{75, 76, 77, 78, 79, 80, 81, 82, 83},
{84, 85, 86, 87, 88, 89, 90, 91, 92},
{93, 94, 95, 96, 97, 98, 99, 100, 101}
byte rowPins[ROWS] = {A3, A2, A1, A0, 15, 14, 16, 10, 9,}; //connect to the row pinouts of the kpd
byte colPins[COLS] = {3, 4, 5, 6, 7, 8}; //connect to the column pinouts of the kpd
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
byte pressed = 32;
byte chanel = 0; // MIDI channel to use
Serial.begin(115200); // set this the same as Hairless
// Fills kpd.key[49] array with up-to 10 active keys.
// Returns true if there are ANY active keys.
if (kpd.getKeys())
for (int i = 0; i < LIST_MAX; i++) // Scan the whole key list.
if ( kpd.key[i].stateChanged ) // Only find keys that have changed state.
pressed = kpd.key[i].kchar - 17;
switch (kpd.key[i].kstate) { // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
case PRESSED:
sendMIDI(chanel | 0x90, pressed, 100);
case RELEASED:
sendMIDI(chanel | 0x80, pressed, 64);
} // End loop
void sendMIDI(byte type, byte note, byte velocity){
Serial.write(type);
Serial.write(note & 0x7F);
Serial.write(velocity);
