I am trying to build a 4x4 launch pad(multiple buttons will be pressed at the same time) as part of a MIDI controller with Arduino Pro Micro and Control Surface library (https://tttapa.github.io/Control-Surface/Doc/Doxygen/index.html)
The problem is that I cannot get MIDI messages to be send through the push buttons.....
I know I am missing something here for sure..
I want to save arduino pins, that is why I chose to use the shift register 74HC165 in order to connect the 16 push buttons to arduino by using only 3 of the arduino pins. The problem is that although the Control Surface library ROCKS! it is still not finished and it is not compatible with shift registers like 74hc165 but only with those that you can use to increase the outputs(74hc595).
So...I had to figure sth out.
I figured a way to take the incoming 8-bit data from the shift register,representing the state of the push buttons and store each of the push button states separately inside the "buttons[8]" array through the bitRead() function so I can access every button state independently.
I faced a problem when trying to declare the buttons with the Control Surface library with each button declared as an element of the buttons[8] array instead of declaring the ard. pin the button is supposed to be hooked.
the following is supposed to convert the byte type variable that stores the state of the buttons in the buttons array, into an integer. Maybe this is completely wrong...I am not entirely sure..
for(int i = 0; i < 8; i++){
if(buttons[i] == 0){
buttons[i] = 0;
else if(buttons[i] == 1){
buttons[i] = 1;
In the code there are 8 push buttons as a proof of concept.
#include <Control_Surface.h>
USBMIDI_Interface midi;
//pl pin num.1 in the shift reg.
int load = 7;
//CE pin 15
int clockEnablePin = 8;
//Q7 pin7 inverted data
int dataIn = 5;
//CP pin 2
int clockIn = 6;
byte incoming = 0;
int buttons[8];
/*declare the buttons somehow
NoteButton btn[8] {
{buttons[0], MIDI_Notes::C(4)},
{buttons[1], MIDI_Notes::C(3)},
{buttons[2], MIDI_Notes::C(5)},
{buttons[3], MIDI_Notes::C(6)},
{buttons[4], MIDI_Notes::C(7)},
{buttons[5], MIDI_Notes::C(8)},
{buttons[6], MIDI_Notes::E(4)},
{buttons[7], MIDI_Notes::E(3)},
void shiftRegister(){
//write the pulse to load pin
digitalWrite(load, LOW);
delayMicroseconds(5);
digitalWrite(load, HIGH);
//Get data from the shift register
digitalWrite(clockIn, HIGH);
digitalWrite(clockEnablePin, LOW);
incoming = shiftIn(dataIn, clockIn, MSBFIRST);
digitalWrite(clockEnablePin, HIGH);
for (int bits = 0; bits < 8; bits++) {
buttons[bits] = bitRead(incoming, bits);
buttons[i] = 0;
buttons[i] = 1;
delay(700);
Control_Surface.begin();
//Serial.begin(115200);
//setup shift regs connections
pinMode(load, OUTPUT);
pinMode(clockEnablePin, OUTPUT);
pinMode(clockIn, OUTPUT);
pinMode(dataIn, INPUT);
shiftRegister();
Control_Surface.loop();
I have managed to send MIDI messages and use knobs,faders and LEDs so that is not the problem here, but the code.....
Any help is highly appreciated!!!! Bare in mind that I am still new to this so brutal code mistakes may exist^^
