Arduino Pro Mini - 3.3 V / 8MHz - Serial Question
Hey Guys
I’m trying to use the Soft Serial to talk to a HC-11 CC1101 RF Board. So far I’ve been unable to atlk to it over the serial pins 0/1, so I wanted to try using the soft serial.
This is my code:
#include <SoftwareSerial.h>
#define SET 12
SoftwareSerial mySerial(10, 11); // RX, TX
  digitalWrite(SET, HIGH);
  pinMode(SET, OUTPUT);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
void loop() { // run over and over
  if( mySerial.available() > 0 ){
    Serial.println("Serial Setup");
    pinMode(SET, LOW);
    mySerial.print(F("AT\r\n"));
    Serial.println("Serial Response");
    Serial.println(mySerial.read());
  Serial.println("Sleeping for 2 seconds");
  delay(2000);
But I never see Serial Setup, so mySerial isn’t available. Does it appear I’m doing anything wrong?
Thanks
docmur
You never print anything to mySerial.
How do you connect Serial (Rx/Tx), so that you can see any output?
while (!Serial) is required only on a Leonardo, is always True on other controllers.
Add some output to Serial in setup(), to verify that this connection is working.
Also make sure that you program the Pro Mini for 3.3V/8Mhz operation, else the baudrate will be wrong.
Something is wrong with both of my HC-11’s. I used my Oscilloscope and the Serial is working fine out o the arduino, but nothing is coming back.
I can’t get them to operate with a full HC-11 sketch and well using my Uno’s or Diecimila. I’m going to order new modules, they’re $5, so it’s not a big deal.
