Arduino Pro Mini 3.3V HC-06 Bluetooth Module
Hello from Japan!
I'm trying to make a cheaper arduinoBT using the Pro Mini 3.3v and the HC-06 Bluetooth Module.
The problem is that verification stage fail after upload
I hope you will be kind to bear with the info below.
Many thanks in advance!
  • OSX 10.6.8
  • Using a directory copy of the BT bootloader
  • Uploaded modified boot loader to Pro Mini 3.3v
  • Modified boards.txt
  • Uploading via bluetooth seems to work (using verbose upload)
  • After upload verification fails
  • Uploading programs via USB ISP is OK!
  • Restoring original Pro Mini 3.3v Boot Loader NO PROBLEM
Boards.txt
BT.name= Arduino HC-06 BT  3.3V/8MHz
BT.upload.protocol=arduino
BT.upload.maximum_size=30720
BT.upload.speed=57600
BT.bootloader.low_fuses=0xFF
BT.bootloader.high_fuses=0xD8
BT.bootloader.extended_fuses=0x05
BT.bootloader.path=regin_bt
BT.bootloader.file=regin_bt.hex
BT.bootloader.unlock_bits=0x3F
BT.bootloader.lock_bits=0x0F
BT.build.mcu=atmega328p
BT.build.f_cpu=8000000L
BT.build.core=arduino
BT.build.variant=standard
Makefile (modified area)
atmega328_bt: TARGET = atmega328_bt
atmega328_bt: MCU_TARGET = atmega328p
atmega328_bt: AVR_FREQ = 8000000L
atmega328_bt: LDSECTION  = --section-start=.text=0x7000
atmega328_bt: $(PROGRAM)_atmega328_bt.hex
Blink program UPLOAD verbose
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/regin_rodriguez/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/tty.Regin_BT02-DevB
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Programmer Type : Arduino
         Description     : Arduino
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [0f]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [03]
         Hardware Version: 2
         Firmware Version: 1.15
avrdude: Send: A [41] . [84]   [20]
avrdude: Recv: . [00]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: u [75]   [20]
avrdude: Recv: . [14] . [1e] . [95] . [0f] . [10]
################################################## | 100% 0.24s
avrdude: Device signature = 0x1e950f
avrdude: Send: V [56] . [a0] . [03] . [fc] . [00]   [20]
avrdude: Send: V [56] . [a0] . [03] . [fd] . [00]   [20]
avrdude: Send: V [56] . [a0] . [03] . [fe] . [00]   [20]
avrdude: Send: V [56] . [a0] . [03] . [ff] . [00]   [20]
avrdude: reading input file "/var/folders/98/98SOfbC9HsmpXuuVf9fn0E+++TI/-Tmp-/build7790539086183957580.tmp/Blink.cpp.hex"
avrdude: writing flash (1108 bytes):
#####avrdude: Send: U [55] @ [40] . [00]   [20]
avrdude: Send: d [64] . [00] . [80] F [46] # [23] . [00] & [26] . [00] ) [29] . [00] . [04] . [04] . [04] . [04] . [04] . [04] . [04] . [04] . [02] . [02] . [02] . [02] . [02] . [02] . [03] . [03] . [03] . [03] . [03] . [03] . [01] . [02] . [04] . [08] . [10]   [20] @ [40] . [80] . [01] . [02] . [04] . [08] . [10]   [20] . [01] . [02] . [04] . [08] . [10]   [20] . [00] . [00] . [00] . [07] . [00] . [02] . [01] . [00] . [00] . [03] . [04] . [06] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [11] $ [24] . [1f] . [be] . [cf] . [ef] . [d8] . [e0] . [de] . [bf] . [cd] . [bf] . [11] . [e0] . [a0] . [e0] . [b1] . [e0] . [e2] . [e5] . [f4] . [e0] . [02] . [c0] . [05] . [90] . [0d] . [92] . [a2] 0 [30] . [b1] . [07] . [d9] . [f7] . [11] . [e0] . [a2] . [e0] . [b1] . [e0] . [01] . [c0] . [1d] . [92] . [ab] 0 [30] . [b1] . [07] . [e1] . [f7] . [0e] . [94] . [18] . [02] . [0c] . [94] ' [27] . [02] . [0c] . [94] . [00] . [00]   [20]
#### | 100% 6.51s
avrdude: 1108 bytes of flash written
avrdude: verifying flash memory against /var/folders/98/98SOfbC9HsmpXuuVf9fn0E+++TI/-Tmp-/build7790539086183957580.tmp/Blink.cpp.hex:
avrdude: load data flash data from input file /var/folders/98/98SOfbC9HsmpXuuVf9fn0E+++TI/-Tmp-/build7790539086183957580.tmp/Blink.cpp.hex:
avrdude: input file /var/folders/98/98SOfbC9HsmpXuuVf9fn0E+++TI/-Tmp-/build7790539086183957580.tmp/Blink.cpp.hex contains 1108 bytes
avrdude: reading on-chip flash data:
Reading | avrdude: Send: U [55] . [00] . [00]   [20]
avrdude: Send: t [74] . [00] . [80] F [46]   [20]
avrdude: Recv: . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff]
#### | 100% 4.49s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0x0c != 0xff
avrdude: verification error; content mismatch
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
Do you have the bluetooth module connected when you try to upload?
Bluetooth connects to the serial pins and that causes conflicts - the program is uploaded over those pins.
For development it's easier to connect the Bluetooth module to some other pins and use SoftSerial.
Hello Fugus,
Thanks for the Reply. Yes it is already connected and working properly. I an upload the ASCII example sketch via SPI and get a valid output via HC-06 output. :slight_smile:
-regin
