The strangest thing happened; I was using Maxuino 007 to let my Arduino communicate with MaxMSP for weeks, while last week it stopped working. Now I am trying to get it working again.
I am using
- Firmata 2.1
- MaxMSP 5.13, running arduino_test.maxpat
- Maxuino 007
- Arduino 0018
- MacBook with OS x Snow leopard.
- Arduino Pro Mini, ATmega328
I uploaded StandardFirmata to the arduino pro mini, closed Arduino 0018, and started arduino_test.maxpat. The arduino is recognized in the patch, but neither the inputs or the outputs are working.
The tx led on the Arduino Serial USB Board is blinking when I start the metro-blink-all-digitalout-thingie in arduino_test.maxpat. However led13 is not blinking.
The arduino is still capable of commicating in general; I can upload blinkled, and I can monitor serial communication in Arduino 0018.
I am using a Diecimila as well, works like a charm using firmata 2.1 and maxuino 007. If I upload the same firmata to the pro mini, neither the inputs or outputs work. Is there perhaps a problem with firmata and the arduino pro mini?
I already tried
- Using a different Arduino Pro Mini, ATmega328; same problems.
- following step by step the tutorial at http://www.soundplusdesign.com/?cat=104
- I tried Maxuino 008 as well, but get the following error: serial: specified port not available.
- Firmata version from Pd Objectclasses, same problems
- Sensor box, does not work either
I would really appreciate any help or advice!
Regards,
Jaap
