Hey all, i am trying to find the parts needed to build a similar build of the sparkfun Arduino Pro Mini board. Does anyone happen to know what the components are called that are used on that board? I’m having a hard time trying to track down the part numbers for them all!
I'm trying tofind the same information.
I just got word on the Voltage regulator,
MIC5205-5.0YM5, Relevent datasheet: http://www.micrel.com/_PDF/mic5205.pdf
Ok, i have been reading the schema and all and i came up with this...
Can you check to make sure the connections are correct and i got the correct components?
The "trace" for the oscillator capacitors looks like it's crossing. It looks like you should "route" the trace from the left capacitor to the north of the other capacitor, right? Since you were color-coding traces, I guess that's top and bottom layer, so I figured it worth mentioning.
Make one.
Look at the photo and back out the parts.
The 10u caps are big, 1210 maybe
the resistors and .1uf caps are 0805 smt.
The 168 is a tqfp-32.
the resonator ?
the voltage regulator is a SOT-23 I think.
Good luck finding LDO voltage regulators, and the 168 tqfp.
168tqfp are due in May(mouser.com).
