If you are using a standard 6v battery to run the arduino should you put the +end into the raw port or vcc?
Thanks
raw
Thanks, one more question. Then do you use the vcc to connect the power to the circuit?
eyan219:
Yes.
Promini regulator is only good for 150mA, be careful about what external devices you connect.
