Hello, this is my first contct with Arduino!
I have a Arduino Pro Mini clone 3,3V and a CH340G USB to TTL Converter.
The Pro Mini have 2 red LED one blink slow the other lights constant.
Now i try to upload the Blink Sketch without success!
The CH340G have 6 Pin GND, RXD, TXD, 3V3, VCC, 5V.
I solder a bridge between 3v3 and VCC and conect GND, RXD, TXD and VCC to the Pro Mini.
The driver of CH340G is installed! My Notebook works wiht Windows 8.1, IDE 1.8.12
Under Tools selectet Pro Mini, ATmega 328P (3,3V 8MHz), COM 4, AVRISP mk2
i have tryed the Upload with pressing the Resetbutton and leav when upload biginns.
Also i have tryed by connecting Pin 13 (DTR) of the IC from CH340G to DTR on the Pro Mini.
I Always get a Fail
Arduino: 1.8.12 (Windows 8.1), Board: "Arduino Pro or Pro Mini, ATmega328P (3.3V, 8 MHz)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\sandra\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\sandra\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\sandra\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=8MHzatmega328 -vid-pid=1A86_7523 -ide-version=10812 -build-path C:\Users\sandra\AppData\Local\Temp\arduino_build_210342 -warnings=none -build-cache C:\Users\sandra\AppData\Local\Temp\arduino_cache_769554 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\sandra\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\sandra\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\sandra\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=8MHzatmega328 -vid-pid=1A86_7523 -ide-version=10812 -build-path C:\Users\sandra\AppData\Local\Temp\arduino_build_210342 -warnings=none -build-cache C:\Users\sandra\AppData\Local\Temp\arduino_cache_769554 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'pro' from platform in folder: C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Using core 'arduino' from platform in folder: C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Detecting libraries used...
"C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10812 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Users\sandra\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\sandra\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\eightanaloginputs" "C:\Users\sandra\AppData\Local\Temp\arduino_build_210342\sketch\Blink.ino.cpp" -o nul
Generating function prototypes...
"C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10812 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Users\sandra\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\sandra\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\eightanaloginputs" "C:\Users\sandra\AppData\Local\Temp\arduino_build_210342\sketch\Blink.ino.cpp" -o "C:\Users\sandra\AppData\Local\Temp\arduino_build_210342\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\sandra\AppData\Local\Temp\arduino_build_210342\preproc\ctags_target_for_gcc_minus_e.cpp"
Sketch wird kompiliert...
"C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10812 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Users\sandra\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\sandra\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\eightanaloginputs" "C:\Users\sandra\AppData\Local\Temp\arduino_build_210342\sketch\Blink.ino.cpp" -o "C:\Users\sandra\AppData\Local\Temp\arduino_build_210342\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\sandra\AppData\Local\Temp\arduino_cache_769554\core\core_arduino_avr_pro_cpu_8MHzatmega328_a80a7f6f51f4328d51aa0c5d65268f99.a
Linking everything together...
"C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\sandra\AppData\Local\Temp\arduino_build_210342/Blink.ino.elf" "C:\Users\sandra\AppData\Local\Temp\arduino_build_210342\sketch\Blink.ino.cpp.o" "C:\Users\sandra\AppData\Local\Temp\arduino_build_210342/..\arduino_cache_769554\core\core_arduino_avr_pro_cpu_8MHzatmega328_a80a7f6f51f4328d51aa0c5d65268f99.a" "-LC:\Users\sandra\AppData\Local\Temp\arduino_build_210342" -lm
"C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\sandra\AppData\Local\Temp\arduino_build_210342/Blink.ino.elf" "C:\Users\sandra\AppData\Local\Temp\arduino_build_210342/Blink.ino.eep"
"C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\sandra\AppData\Local\Temp\arduino_build_210342/Blink.ino.elf" "C:\Users\sandra\AppData\Local\Temp\arduino_build_210342/Blink.ino.hex"
"C:\Users\sandra\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\Users\sandra\AppData\Local\Temp\arduino_build_210342/Blink.ino.elf"
Der Sketch verwendet 924 Bytes (3%) des Programmspeicherplatzes. Das Maximum sind 30720 Bytes.
Globale Variablen verwenden 9 Bytes (0%) des dynamischen Speichers, 2039 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
avrdude: stk500_getsync(): can't communicate with device: resp=0xfc
Beim Hochladen des Sketches ist ein Fehler aufgetreten
