Arduino Pro mini clone and nokia5110 LCD Low memory
Hello i try upload a sketch for to my pro mini clone using the nokia 5110 lcd before i had no problem uploading a test sketch but for some reason I'm getting a error saying
Sketch uses 2,884 bytes (8%) of program storage space. Maximum is 32,256 bytes.
Global variables use 130 bytes (6%) of dynamic memory, leaving 1,918 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
and i uploaded the sketch before never had this problem before not sure what to make of it say low memory so it gets stuck there just saying uploading and that is all can someone please help me out i can not figure why it is going this my sketch is below.
joseph
nokia5110_lcd_display.ino (1.09 KB)
What kind of usb-serial adapter are you using ?
I think the usb-serial adapter or perhaps the bootloader is wrong, or the wiring is not okay.
When I buy a cheap Pro Mini on Ebay, I always burn the newest bootloader to it. I don't trust the bootloader that came with it. It might have been written with a low voltage, or it might be a very old version.
Hello Peter the USB FTDI came with the Pro mini clone it came from ebay this is the pro mini i got http://www.ebay.com/itm/321531263936?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT and this is the ftdi i got http://www.ebay.com/itm/5V-FTDI-Basic-USB-to-Serial-Converter-Use-with-Arduino-Pro-Mini-/200941666656?pt=LH_DefaultDomain_0&hash=item2ec90e8160
It could be a counterfeit FTDI. It could even have been bricked by the FTDI drivers a few weeks ago.
Do you have another usb-serial adapter ?
Does the computer show a serial port ? If there is a serial port, the usb-serial adapter might be okay.
I don't have that specific Pro Mini board with labels BLK and GRN. But if it was working before, I assume it is okay.
Do you have a programmer, or are you willing to try to use an other Arduino board (like the Arduino Uno) as a programmer ?
FTDI works good i can use it on the other pro mini and even my uno breadboard i made. I even tried as different FTDI programmer and came out the same no difference. i even tried to program the pro mini clone with my Uno board and i get the same error.
Okay, two options: The Pro Mini bootloader is corrupted or it is broken.
Did you try your "Uno" to burn the bootloader ? If that is not possible, the ATmega328P might be broken. Or perhaps the crystal is broken. Did you drop it on a concrete floor ?
I think you have to give up on this one. Luckely they are only 3 dollars/euros. I bought one for 1.70 euros and it is working :slight_smile:
Hello Peter i will try to burn the bootloader and no i didn't drop it never drop it. been on my desk for 3 weeks sense i last touched it. But i will try to burn the bootloader and see what happens.
Hello Peter it was the bootloader failed i redid the bootloader and it worked i can use the FTDI on it so some how the bootloader got messed up.
I'm glad it is working. The bootloader gets messed up sometimes. I don't know how that is possible, someone should investigate that :smiley_cat:
yeah. the FTDI works good no problems its a real FTDI chip not a fake one. it works on my other pro mini and i even used it on my 328p chips and works with no problem just that one pro mini was giving problems.
