Arduino Pro mini flashing errors
Hi Everyone
I'm using Arduino 1.8.16 under Ubuntu 21 64x computer.I need to flash bootloader of my Adruino pro mini Mega328p AU1708 and AU1722 devices I tried with extra devices FTDI and USBASP I also tried with Adruino as ISP but didn't work. I think I changed my device signature during the command line avrdude command line test.
Is it possible to set back that signature.
avrdude: AVR device initialized and ready to accept instructions
Error while burning bootloader.
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x0000ff
avrdude: Expected signature for ATmega328P is 1E 95 0F
         Double check chip, or use -F to override this check.
and now
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
Thanks.
To do ICSP programming, the system clock on the target chip has to be running. They should come from the factory with the system clock set to the internal RC clock (8 MHz). If you have EVER tried to burn an Arduino bootloader to them they will be switched to a crystal clock. Do you have an 16 MHz crystal or resonator connected to the chip?
I can't read It's smd component.It seem to be AE?
$ avrdude -C /etc/avrdude.conf -p m328p -P /dev/ttyACM0 -c avrisp -q -F -U lfuse:r:-:i -U hfuse:r:-:i -U efuse:r:-:i
avrdude: Device signature = 0x000000 (retrying)
avrdude: reading lfuse memory:
avrdude: writing output file "<stdout>"
:0100000000FF
:00000001FF
avrdude: reading hfuse memory:
:0100000000FF
:00000001FF
avrdude: reading efuse memory:
:0100000000FF
:00000001FF
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
avrdude done.  Thank you.
Yes now I checked It's Atmega328P Mini 5V 16MHz crystal.And I have also separately a 16mhz crystal available.
Are you saying that your board is an Arduino Mini, like the one shown here?
How are you connecting to the board? Sticking wires in the holes is generally not a good enough connection.
Do you have your ISP device solidly connected to Ground, +5V, 11, 12, 13, and Reset?
I know but I tried a few times with usbasp, ftdi, arduino as isp but with out of success.
The USBasp should have worked. Did you select it under Tools->Programmers? The log you posted says '-c avrisp'.
Are you using:
Tools -> Board: "Arduino Pro or Pro Mini"
Tools -> Processor: "ATmega328P (5V, 16 MHz)"
Tools -> Programmer: "USBasp"
Tools -> BurnBootloader
There is no serial port on usbasp in Arduino IDE.
I checked with multimeter all the connection continuity.My connection on usbasp like this
Black GND GND
Blue RST reset
Red VCC VCC
Yellow #13 SCK
Orange #12 MISO
Green #11 MOSI
Arduino mini 1
Arduino: 1.8.16 (Linux), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
/home/petty/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/home/petty/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -cusbasp -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/home/petty/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
         User configuration file is "/home/petty/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : usbasp
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : usbasp
         Description     : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: error: program enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
         this check.
Arduino mini 2
         Using Port                    : usb
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         this check.
Commandline output
Arduino mini 1
$ avrdude -C /etc/avrdude.conf -p m328p -Pusb -c usbasp -q -F -U lfuse:r:-:i -U hfuse:r:-:i -U efuse:r:-:i
avrdude: Device signature = 0x02e2d2
Arduino mini 2
avrdude: Device signature = 0x4a31dc
I don't know what the problem is. Maybe the chip got fried somehow or maybe the fuses got set to disallow serial programming. If the fuses are the problem, you can fix it with High Voltage Serial Programming. You can do that with one of these:
Maybe try to manually reset the board (press the button) right after you start the flashing process?
It may take a few tries to get the timing correctly though.
For the Adruino as ISP i believe you need an additional capacitor.
Arduino IDE doesn't work with usbasp but I can try on command line avrdude under this circumstances how is the command line command? I'm not sure what is going to be right after -u -U -v parameters.
The error messages seem to indicate avrdude is having problems communicating with the usbasp, so you are never getting far enough to actually attempt to bootload the pro mini.
When using the UNO for Arduino as ISP, you may need a 10uF capacitor between RESET and GND on the UNO.
If you have a voltmeter, check the jumper cables with the ohmmeter to verify they are actually making contact, occasionally the wire will break inside the insulation.
This is normal and expected. The USBasp is pure USB device that does not use a serial port. The selection (or lack of selection) in the Arduino IDE's Tools > Port menu is completely ignored while using the USBasp.
Please provide the back story. Why do you need to do this? The Pro Mini comes with a bootloader pre-installed.
In the last photo you shared, it looks like maybe there is a burn mark on one of the capacitors on the Pro Mini:
7C992AEB-96D3-40F4-80DA-D9EFBD878E82
Was there a "magic smoke" incident?
I coudn't flash anything so I thought I need to flash boodloader and If I press reset button it doesn't flash the leds.
If I measure with my multimeter between GND and VCC pins.
Arduino pro mini 1
1.2k ohm
Arduino pro mini 2
1.3k ohm
i appreciate all of your efforts.
The bootloader only allows you to use the serial port for flashing.
If you can get the USBasp or Adruino as ISP working, you can directly flash a sketch regardless of bootloader existence. This also removes the bootloader though.
Could you check if your USBasp is working fine with your current software? Just plug it into the Uno and try to read it.
Also, did you notice the remark by in0 about that capacitor?
I had a same type pro mini from my other project I2C temperature and Humidity.I try to read and flash blink code and it worked with ftd1232
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/home/petty/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/home/petty/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/tmp/arduino_build_105039/Blink.ino.hex:i
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.16
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/tmp/arduino_build_105039/Blink.ino.hex"
avrdude: writing flash (924 bytes):
Writing | ################################################## | 100% 0.51s
avrdude: 924 bytes of flash written
avrdude: verifying flash memory against /tmp/arduino_build_105039/Blink.ino.hex:
avrdude: load data flash data from input file /tmp/arduino_build_105039/Blink.ino.hex:
avrdude: input file /tmp/arduino_build_105039/Blink.ino.hex contains 924 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.43s
avrdude: verifying ...
avrdude: 924 bytes of flash verified
$ avrdude -c arduino -p atmega328p -P /dev/ttyUSB0 -b57600 -t
avrdude>
I tried same code with other 2 and I get this output something wrong with those two.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
I measures 9.53 uF and the across 9.78 uF.It seems to functional.
Flashing with ftd1232 (or any other USB-Serial adapter) requires a working bootloader.
Flashing with USBasp don't need a bootloader, which is why i recommeded to try get it working.
Here, couple guides for Arduino Pro Mini USBasp programming:
https://www.berezovskyi.me/2015/03/programming-arduino-pro-mini-with-usbasp-v2.0/
Usbasp works with all other arduinos uno mini etc.
Sketch uses 4354 bytes (14%) of program storage space. Maximum is 30720 bytes.
Global variables use 482 bytes (23%) of dynamic memory, leaving 1566 bytes for local variables. Maximum is 2048 bytes.
/home/petty/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/home/petty/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -cusbasp -Pusb -Uflash:w:/tmp/arduino_build_684202/ArduinoISP.ino.hex:i
         Using Port                    : usb
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/tmp/arduino_build_684202/ArduinoISP.ino.hex"
avrdude: writing flash (4354 bytes):
Writing | ################################################## | 100% 2.66s
avrdude: 4354 bytes of flash written
avrdude: verifying flash memory against /tmp/arduino_build_684202/ArduinoISP.ino.hex:
avrdude: load data flash data from input file /tmp/arduino_build_684202/ArduinoISP.ino.hex:
avrdude: input file /tmp/arduino_build_684202/ArduinoISP.ino.hex contains 4354 bytes
Reading | ################################################## | 100% 2.48s
avrdude: 4354 bytes of flash verified
Device 1
         Using Port                    : usb
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         this check.
the selected serial port
 does not exist or your board is not connected
Device 2
         Using Port                    : usb
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         this check.
conclusion both of the devices are broken I guess.
I will take a closer look at those links later.
