Hello everyone.
I bought two Arduino pro mini 3.3V and I was trying to make a radio transmitter and receiver like this.
I couldn't get it work, by the way I realized that the Arduino in the transmitter was getting too hot
I was supplying both with a 9V battery through RAW pin
Even when i connected it through VCC with a 3.3V regulated supply, it still got so hot
I desoldered the regulator and supply it with 3.3V through VCC but it still gets hot
The exact part with gets hot seems to be the programming pins, like RX or VCC
So I meassured the resistance of several pins and here is some of them which are different than the other Arduino which doesn't have any problems:
pin1----pin2:::::damaged Arduino ------- healthy Arduino
VCC-------GND:::::::::::0 ohm!!----------------2 kilo ohms
Well I just realized that VCC and GND are shorted, there isn't any problems with soldering and it was working fine before, what has happened to it? is it fixable at all?! what can cause and Arduino short VCC and GND?!
