Here's the entire code, not sure if it's what you were asking for. The output pins defined in TVout seem to be in hardware_setup.h, so i'm posting it as well.
#include <TVout.h>
#include <video_gen.h> //runs fine without this, but i'm including it anyway
#include "zero.h"
#include "one.h"
#include "two.h"
#include "three.h"
#include "four.h"
#include "five.h"
#include "six.h"
#include "seven.h"
#include "eight.h"
#include "nine.h"
#include "dot.h"
#include "blank.h"
//the images used are 40x64, except dot.h which is 12x49
TVout TV;
const int Time = 2; //pin 2 is used to set time
int TimeState = 0;
int minutes[10] = {zero, one, two, three, four , five, six, seven, eight, nine};
int tensminutes[6] = {zero, one, two, three, four, five};
int hours[10] = {zero, one, two, three, four , five, six, seven, eight, nine};
int tenshours[3] = {zero, one, two};
int m = 0; //minutes
int tm = 0; //tens of minutes
int h = 0; //hours
int th = 0; //tens of hours
int s = 4; // selector
int i = 0; //timer
TV.begin(PAL, 189, 78); //resolution and initial images
TV.bitmap(86, 20, dot);
TV.bitmap(0, 10, zero);
TV.bitmap(43, 10, zero);
TV.bitmap(101, 10, zero);
TV.bitmap(144, 10, zero);
pinMode(Time, INPUT);
unsigned char w;
TimeState = digitalRead(Time);
//selector cycle. if s=1 -> increment minutes, if s=2 -> increment tensminutes...
if (TimeState != HIGH) {
if ((s == 1) && (TimeState != HIGH)) {
TV.bitmap(144, 10, two);
TV.delay (1000);
if ((s == 2) && (TimeState != HIGH)) {
TV.bitmap(144, 10, three);
TV.delay (1000);
if ((s == 3) && (TimeState != HIGH)) {
TV.bitmap(144, 10, four);
TV.delay (1000);
if ((s == 4) && (TimeState != HIGH)) {
TV.bitmap(144, 10, one);
TV.delay (1000);
s = s + 1;
if (s == 5) {
s = 1;
return;
//flashing current time
if (TimeState != LOW) {
TV.bitmap(0, 10, blank);
TV.bitmap(43, 10, blank);
TV.bitmap(101, 10, blank);
TV.bitmap(144, 10, blank);
TV.delay(500);
TV.bitmap(0, 10, tenshours[th]);
TV.bitmap(43, 10, hours[h]);
TV.bitmap(101, 10, tensminutes[tm]);
TV.bitmap(144, 10, minutes[m]);
TV.delay(500);
TV.delay(500);
TV.delay(1000);
//incrementor
point:
m = m + 1;
if (m == 10) {
m = 0;
TV.delay (1000);
else {
TV.delay (1000);
tm = tm + 1;
if (tm == 6) {
tm = 0;
TV.delay (1000);
else {
TV.delay (1000);
h = h + 1;
if (h == 10) {
h = 0;
TV.delay (1000);
else {
TV.delay (1000);
th = th + 1;
if (th == 3) {
th = 0;
TV.delay (1000);
else {
TV.delay (1000);
goto point; //i've heard some people don't like the "goto" function, this is good criticism that i won't be taking into account
//clock
while (i <= 59) {
i = i + 1;
TV.delay(1000);
if (TimeState == LOW) {
i = 0;
return;
i = 0;
m = m + 1;
if (m == 10) {
m = 0;
tm = tm + 1;
if (tm == 6) {
tm = 0;
h = h + 1;
if (h == 10) {
h = 0;
th = th + 1;
if (th == 3) {
th = 0;
if ((h == 4) && (th == 2)) {
h = 0;
th = 0;
//display current time
hardware_setup.h
Copyright (c) 2010 Myles Metzer
Permission is hereby granted, free of charge, to any person
obtaining a copy of this software and associated documentation
files (the "Software"), to deal in the Software without
restriction, including without limitation the rights to use,
copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the
Software is furnished to do so, subject to the following
conditions:
The above copyright notice and this permission notice shall be
included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
OTHER DEALINGS IN THE SOFTWARE.
// sound is output on OC2A
// sync output is on OC1A
//ENABLE_FAST_OUTPUT chooses the highest bit of a port over the original output method
//comment out this line to switch back to the original output pins.
#define ENABLE_FAST_OUTPUT
#ifndef HARDWARE_SETUP_H
#define HARDWARE_SETUP_H
// device specific settings.
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega1281__) || defined(__AVR_ATmega2560__) || defined(__AVR_ATmega2561__)
#if defined(ENABLE_FAST_OUTPUT)
#define PORT_VID PORTA
#define DDR_VID DDRA
#define VID_PIN 7
#else
//video
#define PORT_VID PORTB
#define DDR_VID DDRB
#define VID_PIN 6
#endif
//sync
#define PORT_SYNC PORTB
#define DDR_SYNC DDRB
#define SYNC_PIN 5
//sound
#define PORT_SND PORTB
#define DDR_SND DDRB
#define SND_PIN 4
#elif defined(__AVR_ATmega644__) || defined(__AVR_ATmega644P__) || defined(__AVR_ATmega1284__) || defined(__AVR_ATmega1284P__)
//video
#define VID_PIN 7
#else
#define PORT_VID PORTD
#define DDR_VID DDRD
#define VID_PIN 4
#endif
//sync
#define PORT_SYNC PORTD
#define DDR_SYNC DDRD
#define SYNC_PIN 5
//sound
#define PORT_SND PORTD
#define DDR_SND DDRD
#define SND_PIN 7
#elif defined(__AVR_ATmega8__) || defined(__AVR_ATmega88__) || defined(__AVR_ATmega168P__) || defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__) || defined(__AVR_ATmega328__)
//video
#define VID_PIN 7
#else
#define VID_PIN 0
#endif
//sync
#define SYNC_PIN 1
//sound
#define SND_PIN 3
#elif defined (__AVR_AT90USB1286__)
//video
#define PORT_VID PORTF
#define DDR_VID DDRF
#define VID_PIN 7
//sync
#define SYNC_PIN 5
//sound
#define SND_PIN 4
#elif defined(__AVR_ATmega32U4__) // Modified for Arduino Leonardo
//video
#define VID_PIN 4 // 8
//sync
#define SYNC_PIN 5 // 9
//sound
#define SND_PIN 7 // 11
#define TCCR2A TCCR0A
#define TCCR2B TCCR0B
#define OCR2A OCR0A
#define OCR2B OCR0B
#define COM2A0 COM0A0
#define COM2A1 COM0A1
#define CS20 CS00
#define WGM21 WGM01
#endif
//automatic BST/BLD/ANDI macro definition
#if VID_PIN == 0
#define BLD_HWS "bld r16,0\n\t"
#define BST_HWS "bst r16,0\n\t"
#define ANDI_HWS "andi r16,0xFE\n"
#elif VID_PIN == 1
#define BLD_HWS "bld r16,1\n\t"
#define BST_HWS "bst r16,1\n\t"
#define ANDI_HWS "andi r16,0xFD\n"
#elif VID_PIN == 2
#define BLD_HWS "bld r16,2\n\t"
#define BST_HWS "bst r16,2\n\t"
#define ANDI_HWS "andi r16,0xFB\n"
#elif VID_PIN == 3
#define BLD_HWS "bld r16,3\n\t"
#define BST_HWS "bst r16,3\n\t"
#define ANDI_HWS "andi r16,0xF7\n"
#elif VID_PIN == 4
#define BLD_HWS "bld r16,4\n\t"
#define BST_HWS "bst r16,4\n\t"
#define ANDI_HWS "andi r16,0xEF\n"
#elif VID_PIN == 5
#define BLD_HWS "bld r16,5\n\t"
#define BST_HWS "bst r16,5\n\t"
#define ANDI_HWS "andi r16,0xDF\n"
#elif VID_PIN == 6
#define BLD_HWS "bld r16,6\n\t"
#define BST_HWS "bst r16,6\n\t"
#define ANDI_HWS "andi r16,0xBF\n"
#elif VID_PIN == 7
#define BLD_HWS "bld r16,7\n\t"
#define BST_HWS "bst r16,7\n\t"
#define ANDI_HWS "andi r16,0x7F\n"
#endif
#endif
For the record, the pro mini and arduino uno i have use ATmega 328P
