TomGeorge:
Are you sure when you measure 2.3V that the pin is going HIGH and not HIGH/LOW oscillating?
If you measure that point but with your DMM in AC mode, what do you get?
The fact that the initialization in setup you get 3V3 means you have the pin configured correctly.
You need to look though your code and see if after you turn the output HIGH, somewhere in your code you are then switching it LOW, and this cycles one each loop.
Thanks.. Tom...
Thanks Tom,
I was able to figure out that the APRS_init() function is what causes the pin to stay at this 2.4v level, as when I removed it, the PTT worked perfectly, although whenever I try to send data without this initialization function it causes the Arduino to reset, so it is clearly needed. I used my multimeter to check for AC voltage, and I found that whenever that pin goes to LOW, about .5v of AC shows up, and none when the pin is HIGH.
I'm really confused by this issue, as I can't even figure out if it's a hardware or software issue. When the DRA818v isn't connected to the Arduino PTT, it goes all the way up to 3.3v, but it also seems to work fine when I don't call that APRS_init() function with the DRA818v connected.
Any thoughts?
If you would like my completed code it is below.
#include <baudot.h>
#include <RTTY.h>
#include "DRA818.h"
#include <SoftwareSerial.h>
#include <TinyGPS++.h>
#include <LibAPRS.h>
// Manual update button
#define BUTTON_PIN 13
// GPS SoftwareSerial
// Shares pins with (MISO 12/ MOSI 11) used for SPI
static const int RXPin = 2, TXPin = 3;
static const uint32_t GPSBaud = 9600;
#define PD 14 // to the DRA818 PD pin
#define RX 9 // arduino serial RX pin to the DRA818 TX pin
#define TX 8 // arduino serial TX pin to the DRA818 RX pin
#define PTT 10
#define PWR 11
#define LEDG 17
#define LEDR 16
SoftwareSerial *dra_serial; // Serial connection to DRA818
DRA818 *dra; // the DRA object once instanciated
float freq;
// LibAPRS
#define OPEN_SQUELCH true
#define ADC_REFERENCE REF_3V3
float flat, flon;
// APRS settings
char APRS_CALLSIGN[]="KM4VXF";
const int APRS_SSID=5;
char APRS_SYMBOL='>';
unsigned long startMillis; //some global variables available anywhere in the program
unsigned long currentMillis;
const unsigned long period = 5000; //the value is a number of milliseconds
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
//long instead of float for latitude and longitude
long lat = 0;
long lon = 0;
float alt;
int year=0;
byte month=0, day=0, hour=0, minute=0, second=0, hundredths=0;
unsigned long age=0;
float falt=0;
float fkmph=0;
int ialt=0;
// buffer for conversions
#define CONV_BUF_SIZE 16
static char conv_buf[CONV_BUF_SIZE];
//initialize the LEDS
pinMode(LEDG, OUTPUT);
pinMode(LEDR, OUTPUT);
//Start the DRA818V Module
Serial.println("Booting ...");
Serial.print("initializing I/O ... ");
dra_serial = new SoftwareSerial(RX, TX); // Instantiate the Software Serial Object.
//Turn the DRA818V Power Saving mode off
pinMode(PD, OUTPUT);
digitalWrite(PD, HIGH);
Serial.println("done");
Serial.print("initializing DRA818 ... ");
//Initialize the DRA818V Frequency and info
dra = DRA818::configure(dra_serial, DRA818_VHF, 145.500, 145.500, 4, 8, 0, 0, DRA818_12K5, true, true, true, &Serial);
if (!dra) {
Serial.println("\nError while configuring DRA818");
//Initialize the PTT and the H/L power output
pinMode(PTT, OUTPUT);
pinMode(PWR, OUTPUT);
//Turn the DRA818v to low power
digitalWrite(PWR, LOW);
//Flash the LED
digitalWrite(LEDR, HIGH);
delay(200);
digitalWrite(LEDR, LOW);
delay(200);
delay(200);
Serial.println("Starting ... ");
//Key the DRA818V for one second
digitalWrite(PTT, LOW);
digitalWrite(PTT, HIGH);
//Initialize the GPS
ss.begin(GPSBaud);
Serial.println(F("Arduino APRS Tracker"));
//Initialize the RTTY
RTTY.attach(12);
//Initialize the APRS settings
APRS_init(ADC_REFERENCE, OPEN_SQUELCH);
APRS_setCallsign(APRS_CALLSIGN,APRS_SSID);
APRS_setSymbol(APRS_SYMBOL);
bool newData = false;
// For one second we parse GPS data
for (unsigned long start = millis(); millis() - start < 1000;)
while (ss.available())
char c = ss.read();
// Serial.write(c); // uncomment this line if you want to see the GPS data flowing
if (gps.encode(c)) // Did a new valid sentence come in?
newData = true;
Serial.println(newData);
//if (newData)
long scale=1000000UL;
long lat = gps.location.rawLat().deg*scale+gps.location.rawLat().billionths/1000UL;
if(gps.location.rawLat().negative) lat=-lat;
long lon = gps.location.rawLng().deg*scale+gps.location.rawLng().billionths/1000UL;
if(gps.location.rawLng().negative) lon=-lon;
float alt = gps.altitude.feet();
currentMillis = millis();
if (currentMillis - startMillis >= period) {
Serial.println(F("APRS UPDATE"));
Serial.println(lat);
Serial.println(lon);
Serial.println(deg_to_nmea(lat, true));
Serial.println(deg_to_nmea(lon, false));
Serial.println(alt);
locationUpdate();
delay(2000);
//rttyUpdate();
startMillis = millis();
void rttyUpdate() {
char comment []= "Send data to noahjfodor@protonmail.com or text 407-716-1691";
char temp[8];
char latitude[9];
char longitude[10];
// Convert altitude in string and pad left
sprintf(temp, "%06d", ialt);
dtostrf(flat, 1, 5, latitude);
dtostrf(flon, 1, 5, longitude);
Serial.println("RTTY Update");
ss.end();
digitalWrite(LEDG, HIGH);
RTTY.tx(" \n\n");
RTTY.tx(APRS_CALLSIGN);
RTTY.tx(" WEATHER BALLOON");
RTTY.tx("\n\nLAT/LON: ");
RTTY.tx(latitude);
RTTY.tx(" ");
RTTY.tx(longitude);
RTTY.tx("\nALT: ");
RTTY.tx(temp);
RTTY.tx(" FT");
RTTY.tx("\n");
RTTY.tx(comment);
digitalWrite(LEDG, LOW);
ss.begin(9600);
void locationUpdate() {
//Key the DRA818v
//End the GPS Serial
ss.end();
//Turn on the LED
//Wait 500 ms for the DRA818v to warm up
//Setup the APRS comment
char comment []= "Arduino APRS Tracker";
char temp[8];
char APRS_comment [36]="/A=";
//Setup the APRS comment data
sprintf(temp, "%06f", alt);
strcat(APRS_comment,"ALT: ");
strcat(APRS_comment,temp);
strcat(APRS_comment,"' ");
strcat(APRS_comment,comment);
Serial.println(APRS_comment);
//Set the Lat/Lon
APRS_setLat((char*)deg_to_nmea(lat, true));
APRS_setLon((char*)deg_to_nmea(lon, false));
// TX
APRS_sendLoc(APRS_comment, strlen(APRS_comment));
//Turn off the LED
// start GPS Serial again
ss.begin(9600);
//unkey the radio
** Convert degrees in long format to APRS string format
** DDMM.hhN for latitude and DDDMM.hhW for longitude
** D is degrees, M is minutes and h is hundredths of minutes.
** http://www.aprs.net/vm/DOS/PROTOCOL.HTM
char* deg_to_nmea(long deg, boolean is_lat) {
bool is_negative=0;
if (deg < 0) is_negative=1;
// Use the absolute number for calculation and update the buffer at the end
deg = labs(deg);
unsigned long b = (deg % 1000000UL) * 60UL;
unsigned long a = (deg / 1000000UL) * 100UL + b / 1000000UL;
b = (b % 1000000UL) / 10000UL;
conv_buf[0] = '0';
// in case latitude is a 3 digit number (degrees in long format)
if( a > 9999) {
snprintf(conv_buf , 6, "%04lu", a);
snprintf(conv_buf + 1, 5, "%04lu", a);
conv_buf[5] = '.';
snprintf(conv_buf + 6, 3, "%02lu", b);
conv_buf[9] = '\0';
if (is_lat) {
if (is_negative) {conv_buf[8]='S';}
else conv_buf[8]='N';
return conv_buf+1;
// conv_buf +1 because we want to omit the leading zero
else {
if (is_negative) {conv_buf[8]='W';}
else conv_buf[8]='E';
return conv_buf;
void aprs_msg_callback(struct AX25Msg *msg) {
Noah
