arduino pro mini POV getting bricked
Introduction :
Hi , one years ago i made POV but I couldn’t make to run properly.
I was new to electronics and programming at that time. So I didn’t scratched my head on it and threw it away but now I want to revist that project and find the reason why that didn’t worked. Fortunately I have all the data related to that project. So let me introduce what I made…
Working:
I used Arduino pro mini 3.3v 8MHz and powered it directly using Li-ion battery.
I also attached a hall effect sensor to interrupt pin(2).
For leds I used 9 neo-pixels attached to digital pin 13;
I mounted all of this hardware on piece of acrylic and attached a motor to it.
I also attached a magnet in the stand.
Note :- You can see the pictures to get an idea of hardware
image-1
image-2
video-1
video-2
Problem:
So when i started the motor. It run good for some time and after a while arduino got bricked
code
// NeoPixel Ring simple sketch (c) 2013 Shae Erisson
// released under the GPLv3 license to match the rest of the AdaFruit NeoPixel library
#ifdef __AVR__
  #include <avr/power.h>
#endif
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1
#define PIN            13
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS      9
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int hall = 2;
bool I[]={1,1,1,1,1,1,1,1,1};  // array for led pixel
  attachInterrupt(0, start, FALLING);
  pinMode(hall,INPUT_PULLUP);
  pixels.begin(); // This initializes the NeoPixel library.
//ISR routine
void start(){
  writeletter(I);
 //code for running pixels
void writeletter(boolean letter[]){
 //turn on led pixels accroding to data in array
  for(int p=0;p<NUMPIXELS;p++){
    if(letter[p]==1){
      pixels.setPixelColor(p, pixels.Color(255,255,255));
      else{
         pixels.setPixelColor(p, pixels.Color(0,0,0));
       pixels.show();
  // turn off al leds pixels
      pixels.show();
Note:- I have also attached code file.
Reasons :
According to my knowledge following could the reasons,
  • Nested Interrupts happening as I wrote a lot code in ISR routine.
  • MCU might be having issue with power as it was not regulated and connected directly to battery.
  • Neo-pixel library might be interfering with interrupts in some way.
So what you think might be reason for this kind of behavior.
test_code.ino (1.53 KB)
abdulsamaddabu:
Reasons :
No. Inside an ISR, interrupts are turned off so you won't get any more (except see #3)
Yes.
Yes. The Neopixel library disables/enables interrupts when clocking the data out. You need to move all your ISR code out into a normal function and just have the ISR set a flag. Then, check for the flag and run your code.
