is anybody there make transformerless power supply?
What is the the max current for power up arduino pro mini 5V/16MHz?
can somebody put here scheme for power up pro mini 5v with transformerless adapter, only 4 diodes to make ac to dc and other parts of electronic that is needed in scheme?
Do you want to power the Arduino directly from the mains ? 110V or 230V ac ?
That is possible, but dangerous. A capacitor is used to lower the voltage and current.
i need transformerless scheme, not with transformer, and it would be nice that scheme is with potentiometers for output DC voltage and current so that i can connect some servo motor which use more current and small things like diodes which use small amount of current.
example: if i want make bulb dimmer of 220v on the ceiling, on the lamp, i need something without transformer that i can put mini arduino and transformerless power supply in lamp, and put pir sensor in all this, so when i open any door in hallway that my bulb is turn on.
i think that the biggest consumer for arduino are servo motors (about 2A) if i'm not wrong...
why it's not possible, there is many transformerless schemes on net but i didn't find one with potentiometers. And you can be more specific, what exactly is not possible.
Features:
"RECOM Power RAC Series 1,2, and 3 watt AC/DC Converters are single output ultra-compact universal input AC/DC Converters for PCB mounting. Features include high efficiency, low standby power, and high operating temperature. The RECOM Power RAC 01, 02, and 03 Series also feature a built-in EMC Class B filter and are EN and CE certified. Output voltage range is 3.3VDC to 24VDC, including a 3.8VDC version for battery chargers and GSM modems.
Learn more.
RECOM Power RAC Series 1, 2, and 3 Watt AC/DC Converters now include the new RAC02-SC/277 and RAC03-SCR/277 Series with a wider input voltage range suitable to customers worldwide and can also be used in lighting."
Tony5:
Very funny, normally I am the person that asks for more details
A switching power supply doesn't need the big transformer, but it still has a small transformer.
I thought that you didn't want a transformer at all. It is possible to use a capacitor to lower the voltage, but that can only provide perhaps 20mA which is not enough for the servo motors.
When you are okay with a switching power supply, you can buy it anywhere. They are more common than the big old transformers of the previous century.
