Arduino pro mini send data to raspberry pi
Can anyone help me understand how to connect the arduino mini pro to the raspberry pi to send data from the connected sensors?
Pro mini Tx goes to Raspberry Rx.
Pro mini Rx goes to Raspberry Tx.
Pro mini GND connects to Raspberry GND.
The RPi is a 3.3v device and is not 5v tolerant on the inputs.
The Tx from the Pro mini must go through a level shifter or voltage divider to connect to the RPi Rx.
The Rpi Tx will typically be at voltage levels adequate for the Arduino Rx to recognize as high and low. However its possible that if the voltage on the RPi is low, it might not register as high.
A level shifter on both lines is not a bad idea.
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Unless of course, you are using a 3.3 V Pro Mini which is powered at 3.3 V.
Thank you for the direction.
