Arduino Pro Mini - sketch uploading error
Hello Forum,
Specs:
-Windows 10
-Board: Arduino Pro Mini
-Processor: ATmega328 (3.3V, 8MHz)
-Port: COM4
-Programmer: AVRISP mkII
-Cannot upload "Blink" program example to board. The error message is as follows:
Arduino: 1.8.5 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328P (3.3V, 8 MHz)"
Archiving built core (caching) in: C:\Users\Clinton\AppData\Local\Temp\arduino_cache_733014\core\core_arduino_avr_pro_cpu_8MHzatmega328_95e00b8c94cab55672a017d4a38e8bf6.a
Sketch uses 928 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Users\Clinton\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\Clinton\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b57600 -D -Uflash:w:C:\Users\Clinton\AppData\Local\Temp\arduino_build_669862/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Clinton\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x9d
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences. (I have reviewed the troubleshooting page instructions and followed them, but no change in symptoms has occurred.)
Thanks for any insight or help with this issue.
-Clinton Chard
