Arduino pro mini sleep Mode power consumption
Hi
I am using arduino pro mini with NRF24L01 to transmit data from one device to another.
I have removed LED of pro mini.
In transmission mode i am getting 10mA, But the problem is in sleep mode i a getting around 5mA which is not good.
Can someone please check the codes and help me what is wrong and what changes i should make.
codes are in the attachment
Receiver.ino (5.97 KB)
Transmiter.ino (8.99 KB)
If the transmitter has a sleep mode, use it as well. Else cut off the transmitter power supply during sleep.
Remove the regulator from the Pro Mini and run it at 8 MHz and ~3V battery power. That will get the current consumption to microamps or nanoamps during sleep.
See this solar powered Arduino/NRF24L01 project for ideas.
Disable the Pro Mini VCC LED as well.
I have removed vcc led of the pro mini. But I have not removed voltage regulator but working with 3v 8MHz.
Is everything fine with the code? Do I need to make any changes?
bmg1234:
What is the sleep current now ?
