Arduino pro mini stopped working.
Hello,
today I was uploading programs to my arduino pro mini 3,3V ATmega328, 8Mhz (with USBasp through SPI pins) and after some few times it stopped working. Nothing in wiring changed so it isn’t the problem, I also cannot burn the bootloader I immediately receive information as follow:
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
Błąd przy wgrywaniu bootloadera.
this check.
Also program that supposed to be on the board is not executed anymore but at first something was working.(still not as planned but working)
Anything else I can mention that restart is going low as well with the button and when program starts, but led isn’t blinking when it happens I don’t know if it was always like this. I mean basically only one led is on when I try to burn bootloader or upload sketch the other diode blinks only for fracture of second and then error comes.
Same error in case of uploading sketch:
this check.
I think it is also worth mentioning that it stopped working after uploading this code:
#include <SPI.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
//Assign the Chip Select signal to pin 10.
int CS=10;
//This is a list of some of the registers available on the ADXL345.
//To learn more about these and the rest of the registers on the ADXL345, read the datasheet!
char POWER_CTL = 0x2D;  //Power Control Register
char DATA_FORMAT = 0x31;
char DATAX0 = 0x32; //X-Axis Data 0
char DATAX1 = 0x33; //X-Axis Data 1
char DATAY0 = 0x34; //Y-Axis Data 0
char DATAY1 = 0x35; //Y-Axis Data 1
char DATAZ0 = 0x36; //Z-Axis Data 0
char DATAZ1 = 0x37; //Z-Axis Data 1
//This buffer will hold values read from the ADXL345 registers.
char values[10];
//These variables will be used to hold the x,y and z axis accelerometer values.
int x,y,z,x1,y1,z1;
void setup(){
  //Initiate an SPI communication instance.
  SPI.begin();
  //Configure the SPI connection for the ADXL345.
  SPI.setDataMode(SPI_MODE3);
[b]SPI.setClockDivider(SPI_CLOCK_DIV4);[color=red][/color][/b]
  //Create a serial connection to display the data on the terminal.
  //Set up the Chip Select pin to be an output from the Arduino.
  pinMode(CS, OUTPUT);
  //Before communication starts, the Chip Select pin needs to be set high.
  digitalWrite(CS, HIGH);
  //Put the ADXL345 into +/- 4G range by writing the value 0x01 to the DATA_FORMAT register.
  writeRegister(DATA_FORMAT, 0x01 |0x08);
  //Put the ADXL345 into Measurement Mode by writing 0x08 to the POWER_CTL register.
  writeRegister(POWER_CTL, 0x08);  //Measurement mode
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.display();
void loop(){
  //Reading 6 bytes of data starting at register DATAX0 will retrieve the x,y and z acceleration values from the ADXL345.
  //The results of the read operation will get stored to the values[] buffer.
  readRegister(DATAX0, 6, values);
  //The ADXL345 gives 10-bit acceleration values, but they are stored as bytes (8-bits). To get the full value, two bytes must be combined for each axis.
  //The X value is stored in values[0] and values[1].
  x = ((int)values[1]<<8)|(int)values[0];
  //The Y value is stored in values[2] and values[3].
  y = ((int)values[3]<<8)|(int)values[2];
  //The Z value is stored in values[4] and values[5].
  z = ((int)values[5]<<8)|(int)values[4];
   x1 = ((int)values[1]<<8)|(int)values[0];
  y1 = ((int)values[3]<<8)|(int)values[2];
  z1 = ((int)values[5]<<8)|(int)values[4];
  //Print the results to the terminal.
  Serial.print(x, DEC);
  Serial.print(',');
  Serial.print(y, DEC);
  Serial.print(',');
  Serial.println(z, DEC);
  delay(10);
  lcd.clear();
  lcd.print(x, DEC);
  lcd.print(',');
  lcd.print(y, DEC);
  lcd.print(',');
  lcd.print(z, DEC);
  lcd.setCursor(0, 1);
  lcd.print(x1);
  lcd.print(',');
  lcd.print(y1);
  lcd.print(',');
  lcd.print(z1);
   lcd.clear();
//This function will write a value to a register on the ADXL345.
//Parameters:
//  char registerAddress - The register to write a value to
//  char value - The value to be written to the specified register.
void writeRegister(char registerAddress, char value){
  //Set Chip Select pin low to signal the beginning of an SPI packet.
  digitalWrite(CS, LOW);
  //Transfer the register address over SPI.
  int a=SPI.transfer(registerAddress);
  //Transfer the desired register value over SPI.
  int b=SPI.transfer(value);
  //Set the Chip Select pin high to signal the end of an SPI packet.
  lcd.print("a=");
  lcd.print(a, HEX);
  lcd.print("b=");
  lcd.print(b, HEX);
  delay(5000);
//This function will read a certain number of registers starting from a specified address and store their values in a buffer.
//Parameters:
//  char registerAddress - The register addresse to start the read sequence from.
//  int numBytes - The number of registers that should be read.
//  char * values - A pointer to a buffer where the results of the operation should be stored.
void readRegister(char registerAddress, int numBytes, char * values){
  //Since we're performing a read operation, the most significant bit of the register address should be set.
  char address = 0x80 | registerAddress;
  //If we're doing a multi-byte read, bit 6 needs to be set as well.
  if(numBytes > 1)address = address | 0x40;
  //Set the Chip select pin low to start an SPI packet.
  //Transfer the starting register address that needs to be read.
  SPI.transfer(address);
  //Continue to read registers until we've read the number specified, storing the results to the input buffer.
  for(int i=0; i<numBytes; i++){
    values[i] = SPI.transfer(0x00);
  //Set the Chips Select pin high to end the SPI packet.
  digitalWrite(CS, HIGH);s
Maybe SPI.setClockDivider(SPI_CLOCK_DIV4); have something to do with this problem.
I also tested USBasp with Arduino uno board and it is working properly.
PS. I know it is not wrong wiring or board selecting from Arduino software, maybe some values that were send over SPI (from arduino to USBasp could initiate some damaging response I have no idea :confused: )
Suspect loose wires or other similar problem. If you're programming by ISP programming, the only way to brick it is to burn bogus fuse settings (like telling it to use a crystal or external clock source and not connecting one, or disabling SPI programming). Fuses are not written when uploading program, only while burning bootloader.
On a Pro Mini, it should not be possible to to anything bad while burning bootloader unless you removed parts from the board, or added boards.txt entries with inappropriate fuse values, selected on of those, and did burn bootloader.
So yeah - hate to say it, but investigate the simple stuff again.
