Arduino pro mini - weird currents in VCC/RAW
Hi all,
I have found something weird (at least for me) playing around with the Arduino pro mini (328p/16Mhz)
With a program like this:
When I connect a regulated 5v power to vcc/gnd, the current is about 50 mA. However, if I connect those 5V to the raw/gnd, the current is about 20 mA. I was expecting more current when I use the raw pin because of the voltage regulator.
What am I missing?
Best,
Limon18
My guess is that 5V is too little and it has not left reset, and thus is not drawing much current.
Hi Nick,
Thanks for your guest. Anyway, I have just tried the following code:
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);
  digitalWrite(13, LOW);
and the led is blinking either ways (connected to VCC or RAW). And the current is more or less the same...
So it's not 20mA/50mA?
This doesn't seem to be an installation issue then.
Nope, still:
VCC - 50mA
Raw - 20mA
There is going to be a voltage drop through the voltage regulator (the "drop-out voltage"). Thus it is running on a lower voltage when you put 5V into RAW.
Can you measure what VCC is when you power it via RAW?
If you exceed the regulator's output setpoint, it generally functions as a (very tight) Zener.
It is about 4.70V
