Arduino - Problem uploading to board (any sketch)
Ive checked board and usb are working & connected to correct port
Grove software or basics programmes have the same problem. My mac has high sierra installed
Newbie so please help! thanks
Arduino: 1.8.19 (Mac OS X), Board: "Arduino Uno"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/neilhanrahan/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/neilhanrahan/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/neilhanrahan/Documents/Arduino/Sketchbook_Starter_Kit_V2-2.0-master/libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10819 -build-path /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986 -warnings=default -build-cache /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_cache_50675 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.avrdude.path=/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -verbose /Users/neilhanrahan/Documents/Arduino/Sketchbook_Starter_Kit_V2-2.0-master/Grove_Sound_Sensor/Grove_Sound_Sensor.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/neilhanrahan/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/neilhanrahan/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/neilhanrahan/Documents/Arduino/Sketchbook_Starter_Kit_V2-2.0-master/libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10819 -build-path /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986 -warnings=default -build-cache /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_cache_50675 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.avrdude.path=/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -verbose /Users/neilhanrahan/Documents/Arduino/Sketchbook_Starter_Kit_V2-2.0-master/Grove_Sound_Sensor/Grove_Sound_Sensor.ino
Using board 'uno' from platform in folder: /Users/neilhanrahan/Library/Arduino15/packages/arduino/hardware/avr/1.8.4
Using core 'arduino' from platform in folder: /Users/neilhanrahan/Library/Arduino15/packages/arduino/hardware/avr/1.8.4
Detecting libraries used...
/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/neilhanrahan/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/neilhanrahan/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986/sketch/Grove_Sound_Sensor.ino.cpp -o /dev/null
Generating function prototypes...
/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/neilhanrahan/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/neilhanrahan/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986/sketch/Grove_Sound_Sensor.ino.cpp -o /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/neilhanrahan/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/neilhanrahan/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986/sketch/Grove_Sound_Sensor.ino.cpp -o /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986/sketch/Grove_Sound_Sensor.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_cache_50675/core/core_arduino_avr_uno_677dd2783e3b676d4861a2b7765ef228.a
Linking everything together...
/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986/Grove_Sound_Sensor.ino.elf /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986/sketch/Grove_Sound_Sensor.ino.cpp.o /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986/../arduino_cache_50675/core/core_arduino_avr_uno_677dd2783e3b676d4861a2b7765ef228.a -L/var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986 -lm
/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986/Grove_Sound_Sensor.ino.elf /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986/Grove_Sound_Sensor.ino.eep
/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -R .eeprom /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986/Grove_Sound_Sensor.ino.elf /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986/Grove_Sound_Sensor.ino.hex
/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-size -A /var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986/Grove_Sound_Sensor.ino.elf
Sketch uses 918 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodemFA131 -b115200 -D -Uflash:w:/var/folders/06/nxpdk2b55dncg8cbvmjcydnc0000gn/T/arduino_build_400986/Grove_Sound_Sensor.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "/Users/neilhanrahan/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
     User configuration file is "/Users/neilhanrahan/.avrduderc"
     User configuration file does not exist or is not a regular file, skipping
     Using Port                    : /dev/cu.usbmodemFA131
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
I have no idea where to find the drivers in the Windows store version of the application; have you tried to look for hidden directories and files.
I suggest that you uninstall the Windows store version and install the normal version (Windows installer). After that you should be able to find the drivers in C:\Program Files (x86)\Arduino\drivers.
Thanks for the suggestion, however I am not sure what you mean by uninstalling and reinstalling with "the ordinary version" also remember I'm on IOS and not windows?
OOPS, must have been confused with another topic.
Apologies.
