Arduino problem
I need help to solve My problems with Arduino .
I have to ARDUINO MEGA Boards
the first one communicate with the com port 4 but when i try to upload program to it , the sketch tell me that the communication port may be used bye another program . bye using task manager i ended all programs that use any port and i restarted my computer . then i tried to upload the program again but the sketch give me the following
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x10
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
the Second Board don't identify on my computer and i it processor become very hot quickly
please tell me what can i do to solve this problems
thanks for help
ensure to select correct card in the IDE before uploading.
That second card.. inspect for shorts. / may be defective
thanks for your help
i right board was selected
and i would like to know how to inspect for short
I've had this problem and sorted it by:
1] open 'Device Manager' by right clicking start in Win 8.x and once more clicking "Device Manager"
2] Run down the list until you see 'Ports "Com and Lpt" '
3] left click it.
4] There you will find the Arduino [generally] listed under its generic name and providing the com port number (x).
5] This is of course the serial port number that should be in the serial port section of the Arduino tools drop down menu If its not then go to the drop down box and type it in.
6] If you want to make sure that your Arduino is connected to this port then right click the line in device centre, click 'Uninstall' then
7] Traverse your mouse to the top of the device centre column and right click your computers name/title and in the drop down box click "Scan for hardware changes" whereupon your computer will scan every piece of internal, external and attached pieces of hardware and if any change is found and in your case you have removed the Arduino device centre info so it will believethat this is now new, reinstall the Arduino and all necessary drivers and quote the com (serial) port to which it is attached.
8] Then if necessary ( I didn't find it so ) carry out 1] to 5] of these instructions once more & BINGO!
With luck and good management you will be free of your problem. Good Luck. Take care some of these operations require cool, calm, careful and collected manipulation.
Cheers,
Chris S.
thanks Chris S for your help
i carried out the steps that you mentioned and i'm sure the sketch is selecting the same serial port number that the arduino identified on it on my computer but the same problem still as you see in the image i attached the sketch doesn't upload the program and the program don't upload and timeout
king_king:
Try down loading the IDE., from Messrs Adafruit. I use their download, Arduino IDE., simply because I cannot use the Arduino IDE or rather when I down load Arduino IDE., from Arduino in Win 8.1 it don't work, no way. Make sure that you clear out the Arduino IDE., that is currently installed before downloading form Adafruit. If you down load from Arduino and try to obtain a program other than for your OS., Arduino are far to clever and you get the IDE for your OS wheras the Adafruit IDE., is not Win x.y dependent.
Let me know if that doesn't work!!!!!!
Chris S.
..Got a second USB-cable? Try it.
Look closely - check sides of MCU for soldering errors (compare your cards)
thanks Chris S
i downloaded the IDE 1.0.5-r2 from the ARDUINO webpage but the same problem appear
thanks knut_ny
i tried another USB cable and checked the MCU soldering but the same problem appear
can you tell me how to test MCU if it work properly or not ?
thanks again for your help
You said the MCU (atmega-chip) gets hot when USB-power is connected. This should not happen and it indicates that the MCU is defective.
Tell your supplier replace the board.
Dear knut_ny
i have tow arduino boards first one when i connect it via USB cable the micro controller become very hot in moment ,and my computer can not recognize it and i thought the reason of this that i made a fault connection on the ARDUINO board but i want to repair it if i can so i need to know which components i should to inspect it before changing the micro-controller
the second board when i connect it to my computer via the USB cable the computer recognize it but when i trying to upload a program to it i get error communication timeout . i thought that this board work properly but there are some thing i miss to do to overcome the error of communication timeout error .
i hope to help me overcome this issues
thanks a lot for your efforts
Best Regards
The 'hot' one: inspect board for soldering shortcircuits. I would contact supplier and get that one replaced.
Do u know which bootlader is present in the working MCU? There are a couple of them.
I'd try an earler version of the IDE (0.23) - it has a slightly different setup in the boards.txt file.
There is another post talking about this issue..
i don't know what is the version of boot loader but i was use it with Arduino sketch V 1.0
out of ideas.
Last shot: compare files 'boards'.. There has been a change to som parameters in repect to bootloaders.
there is other thred discussing this subject
king_king:
thanks Chris S
I know that doesn't work. That's why I told you to download the IDE from Adafruit. This Arduino IDE from Adafruit is not Mileneum; Windows.xx; Windows XP; Vista; 2000, Win, 7 or Win 8 dependent and it runs perfectly in Windows 7 & 8'
DO NOT DOWNLOAD THE ARDUINO IDE FOR WIN 8., FROM AEDUUINO.CC - I T W I L L N O T W O R K...........Period.
Download the Arduino operating system from ...................A D A F R U I T . C O M..................................................................Period.
One day in the future I am sure it will but at the moment Arduino IDE downloaded from Arduino.cc will not work in Win 8.
Chris S
please tell me more about how to download it from A D A F R U I T
thanks
http://adafruit-download.s3.amazonaws.com/Adafruit%20Arduino%201.05%20-%20Win%203-13-14%20.zip
thanks knut_ny for your help
i downloaded it and the result was
time out communicating with programmer
is it hardware fault ??
card shows up=> communication chip OK.
If you have reason to belive that the atmega chip is OK ? , try uploading a new bootloader.
There are several "howto"s ..
