I am trying to make, my own arduino board but I cant get the arduino ide to send program to
board. I watch a youtube video call "$2 Arduino The ATMEGA328 " and I cant get pass the 3:10
part of the video. instead I get this message on the bottom. Please help.
Arduino: 1.8.8 (Windows Store 1.8.19.0) (Windows 10), Board: "ATmega328 on a breadboard (8 MHz internal clock)"
Warning: Board breadboard:avr:atmega328bb doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328BB
Bootloader file specified but missing: C:\Users\Scotty Willimas\Documents\Arduino\hardware\breadboard\avr\bootloaders\ATmegaBOOT_168_atmega328_pro_8MHz.hex
Sketch uses 4400 bytes (14%) of program storage space. Maximum is 30720 bytes.
Global variables use 482 bytes of dynamic memory.
Error while uploading: missing 'upload.tool' configuration parameter
option enabled in File -> Preferences.
DrDiettrich:
You either have to define a "build.board" preference, or download the indicated bootloader file.
The build.board thing is not the problem. It's just a warning. The Arduino IDE automatically sets that property when it's missing.
SIRMAX1:
This indicates that you have downloaded and installed the "Breadboard1-5-x.zip" version of the "ATmega328 on a breadboard" hardware package. That version is incompatible with the Arduino IDE 1.8.8 you're using. The version you need to use is "breadboard-1-6-x.zip".
I try following the direction, but when I try to burn the bootloader the program I get this message.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd9
Problem uploading to board. See Arduino Help Center for suggestions.
Please help me. I don't know what I'm doing wrong?
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.19.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM8
Using Programmer : arduino
Overriding Baud Rate : 19200
avrdude done. Thank you.
Error while burning bootloader.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.19.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.19.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM8 -b57600 -D -Uflash:w:C:\Users\Scotty Willimas\AppData\Local\Temp\arduino_build_533115/ArduinoISP.ino.hex:i
Using Port : COM8
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xa6
You need to select the board that matches your programmer board when you are uploading to that board. If your programmer board is an Uno, then you need to select Tools > Port > Arduino/Genuino Uno Correction: Tools > Board > Arduino/Genuino Uno.
Using Port : COM8
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x85
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x85
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x85
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x85
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x85
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x85
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x85
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x85
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x85
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x85
