Arduino Problems in Coin Acceptor
Hi guys I just want to share about the problem I have experienced with my arduino,
Case: The project I am working is actually an Arduino coin acceptor to count the coins that I have inserted (pulse). It works fine in my first try and my Arduino components are new. But after so many attempts and changes when I try to make my Arduino data to be posted online the pulse is no longer accurate and now the pulse is no longer counting.
Q: Could it be my Arduino is damaged but I run basic program but it was still blinking or maybe there is a loose wire?
You do realise you have told us nothing of any significance?
@pressxx, your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advise on) your project :wink: See About the Installation & Troubleshooting category.
Please provide your code (and please use code tags as described in How to get the best out of this forum).
Please provide a schematic / wiring diagram; a reasnonable sized photo (around 300 kB or so) of a handdrawn one is fine. Make sureit also shows all power and ground connections.
my ball is broken...
@J-M-L , it's nearly Christmas :smiley:
are you getting me a new one? :wink:
I'm sorry , if you can't advise it's still ok thanks
Yes, absolutely correct. It is possible that your Arduino is damaged or you have a loose wire. It is also possible that there is a mistake in your sketch.
Thank you sir
It is now fine sir my Arduino is actually damaged and I have buy a new one and it's working thanks
Whew! :cold_sweat:
Glad we got that sorted. :yawning_face:
