Arduino + Processing, interpreting data
BACKGROUND INFORMATION: Hi, I am working on a processing sketch that uses the 6DOF IMU from sparkfun. I pretty much followed this tutorial and everything seems nice and dandy. HOWEVER! I want to add more to it, I want it to additionally draw 2 rectangles. and I want those rectangles to react to my arduino. SETUP: - Arduino mini 328P - 6DOF IMU - 2 potentiometers set up (using this tutorial ) so far for my Processing code it seems like its working fine (the additional rectangles are being drawn) HOWEVER! those rectangles are just sitting there, I have no clue how to make them react to my arduino. I want to do the following:
void setup(){
size(640,480,P2D);
smooth();
rectangle1 = createShape(RECT, 50, 50,100,50);
rectangle2 = createShape(RECT, 175,50,100,50);
void draw()
  // DRAW THE BOXES THAT REPRESENT EACH CHANNEL AND THEIR RESPONSE TO THE CHANNEL VALUE
  if(channel[0]>799){
  rectangle1.setFill(color(0,255,0));}
  else{
    rectangle1.setFill(color(255,0,0))
  shape(rectangle1);
  shape(rectangle2);
  if(channel[1]>799){
  rectangle2.setFill(color(0,255,0));}
  else{
    rectangle2.setFill(color(255,0,0))
As you can see, what I want is for the rectangles to change from red to green depending on the value of the potentiometer (if its over 800 to change)
I am not sure if this code will be recurring (i want it to change back and forth depending on the values)
ANYWAYS, enough of background information.
[u]THE PROBLEM:[/u]
I am trying to send additional values to the processing sketch via the arduino, so basically my serial monitor in the arduino is (77917F3F,00000000,00000000,00000000) (IMU DATA) (900,345) (ADDITIONAL ANALOG INPUTS)
now, from what I read on the processing sketch, this is how it "decodes" the data obtained:
float decodeFloat(String inString) {
  byte [] inData = new byte[4];
  if (inString.length() == 8) {
    inData[0] = (byte) unhex(inString.substring(0, 2));
    inData[1] = (byte) unhex(inString.substring(2, 4));
    inData[2] = (byte) unhex(inString.substring(4, 6));
    inData[3] = (byte) unhex(inString.substring(6, 8));
and basically stores it in the array inData
however, if I send this new serial to the sketch it goes bonkers since its trying to read the analog values and decode them using the IMU sketch. I want to tell it "no no, read every second line instead of every line" or something along those lines, maybe make the serial output just one big line? (77917F3F,00000000,00000000,00000000)(900,456)
but then again, how do I tell processing: "just read the first parenthesis for the IMU and the second parenthesis for the rectangles"
thank you!
In your Processing sketch, channel[0] and channel[1] are undefined and never valued.
We need to see ALL of the Processing sketch AND the Arduino code.
thanks for the reply, heres the full arduino code, I am highlighting what I added (thats not from the tutorials I listed)
// Arduino firmware for use with FreeSixCube processing example
#include <FreeSixIMU.h>
#include <FIMU_ADXL345.h>
#include <FIMU_ITG3200.h>
#define DEBUG
#ifdef DEBUG
#include "DebugUtils.h"
#endif
#include "CommunicationUtils.h"
#include "FreeSixIMU.h"
#include <Wire.h>
float q[4]; //hold q values
// Set the FreeIMU object
FreeSixIMU my3IMU = FreeSixIMU();
  Wire.begin();
  delay(5);
  my3IMU.init();
  delay(5);
  my3IMU.getQ(q);
  serialPrintFloatArr(q, 4);
    // Declare variables that will store values read from each sensor
float channels[5];
  //read input pins with analog values
  channels[0] = analogRead(A0);
  channels[1] = analogRead(A1);
  channels[2] = analogRead(A2);
  channels[3]= analogRead(A3);
  channels[4] = analogRead(A4);
  //print value on the serial monitor screen
  Serial.print(" ("); Serial.print(channels[0]);
  Serial.print(","); Serial.print(channels[1]);
  Serial.print(","); Serial.print(channels[2]);
  Serial.print(","); Serial.print(channels[3]);
  Serial.print(",");  Serial.println(channels[4]);
  Serial.print(")");
  Serial.println(""); //line break
  delay(60);
and here is the full processing code, NOTE: its not finished yet since I am still working on the parts I mentioned above
I marked what I added, most of this code is not mine
import processing.serial.*;
Serial myPort;  // Create object from Serial class
final String serialPort = COM4; // replace this with your serial port. On windows you will need something like "COM1".
float [] q = new float [4];
float [] hq = null;
float [] Euler = new float [3]; // psi, theta, phi
// THIS IS MY CODE
float [] channels = new float[5] //END OF MY CODE
int lf = 10; // 10 is '\n' in ASCII
byte[] inBuffer = new byte[22]; // this is the number of chars on each line from the Arduino (including /r/n)
PFont font;
final int VIEW_SIZE_X = 800, VIEW_SIZE_Y = 600;
  size(VIEW_SIZE_X, VIEW_SIZE_Y, P3D);
  myPort = new Serial(this, serialPort, 115200);
  font = createFont("Courier", 32);
  float [] axis = new float[3];
   axis[0] = 0.0;
   axis[1] = 0.0;
   axis[2] = 1.0;
   float angle = PI/2.0;
   hq = quatAxisAngle(axis, angle);
   hq = new float[4];
   hq[0] = 0.0;
   hq[1] = 0.0;
   hq[2] = 0.0;
   hq[3] = 1.0;
  delay(100);
  myPort.clear();
  myPort.write("1");
  // THIS IS MY CODE
  smooth();
rectangle3 = createShape(RECT, 300,50,100,50);
rectangle4 = createShape(RECT, 425,50,100,50);
// END OF MY CODE
  int intbits = (inData[3] << 24) | ((inData[2] & 0xff) << 16) | ((inData[1] & 0xff) << 8) | (inData[0] & 0xff);
  return Float.intBitsToFloat(intbits);
void readQ() {
  if (myPort.available() >= 18) {
    String inputString = myPort.readStringUntil('\n');
    //print(inputString);
    if (inputString != null && inputString.length() > 0) {
      String [] inputStringArr = split(inputString, ",");
      if (inputStringArr.length >= 5) { // q1,q2,q3,q4,\r\n so we have 5 elements
        q[0] = decodeFloat(inputStringArr[0]);
        q[1] = decodeFloat(inputStringArr[1]);
        q[2] = decodeFloat(inputStringArr[2]);
        q[3] = decodeFloat(inputStringArr[3]);
//MY CODE STARTS
        channels[0] = inputStringArr[4]
        channels[1] = inputStringArr[5]
        channels[2] = inputStringArr[6]
        channels[3] = inputStringArr[7]
        channels[4] = inputStringArr[8]
        // MY CODE ENDS
void readS() {
        s[0] = decodeFloat(inputStringArr[0]);
        s[1] = decodeFloat(inputStringArr[1]);
        s[2] = decodeFloat(inputStringArr[2]);
        s[3] = decodeFloat(inputStringArr[3]);
void buildBoxShape() {
  //box(60, 10, 40);
  noStroke();
  beginShape(QUADS);
  //Z+ (to the drawing area)
  fill(#00ff00);
  vertex(-30, -5, 20);
  vertex(30, -5, 20);
  vertex(30, 5, 20);
  vertex(-30, 5, 20);
  //Z-
  fill(#0000ff);
  vertex(-30, -5, -20);
  vertex(30, -5, -20);
  vertex(30, 5, -20);
  vertex(-30, 5, -20);
  //X-
  fill(#ff0000);
  vertex(-30, 5, 20);
  //X+
  fill(#ffff00);
  vertex(30, -5, 20);
  vertex(30, 5, 20);
  vertex(30, 5, -20);
  //Y-
  fill(#ff00ff);
  vertex(30, -5, 20);
  //Y+
  fill(#00ffff);
  vertex(30, 5, -20);
  vertex(30, 5, 20);
  vertex(-30, 5, 20);
  endShape();
void drawCube() {
  pushMatrix();
  translate(VIEW_SIZE_X/2, VIEW_SIZE_Y/2 + 50, 0);
  scale(5, 5, 5);
  // a demonstration of the following is at
  // http://www.varesano.net/blog/fabio/ahrs-sensor-fusion-orientation-filter-3d-graphical-rotating-cube
  rotateZ(-Euler[2]);
  rotateX(-Euler[1]);
  rotateY(-Euler[0]);
  buildBoxShape();
  popMatrix();
void draw() {
  background(#000000);
  fill(#ffffff);
  readQ();
  if (hq != null) { // use home quaternion
    quaternionToEuler(quatProd(hq, q), Euler);
    text("Disable home position by pressing \"n\"", 20, VIEW_SIZE_Y - 30);
  else {
    quaternionToEuler(q, Euler);
    text("Point FreeIMU's X axis to your monitor then press \"h\"", 20, VIEW_SIZE_Y - 30);
  textFont(font, 20);
  textAlign(LEFT, TOP);
  text("Q:\n" + q[0] + "\n" + q[1] + "\n" + q[2] + "\n" + q[3], 20, 20);
  text("Euler Angles:\nYaw (psi)  : " + degrees(Euler[0]) + "\nPitch (theta): " + degrees(Euler[1]) + "\nRoll (phi)  : " + degrees(Euler[2]), 200, 20);
  drawCube();
  // THIS IS MY CODE
  if(channel[0]>799){
  else{
  shape(rectangle1);
  shape(rectangle2);
  if(channel[1]>799){
  else{
  shape(rectangle3);
  if(channel[2]>799){
  rectangle3.setFill(color(0,255,0));}
  else{
    rectangle3.setFill(color(255,0,0))
  shape(rectangle4);
  if(channel[3]>799){
  rectangle4.setFill(color(0,255,0));}
  else{
    rectangle4.setFill(color(255,0,0))
  // END OF MY CODE
void keyPressed() {
  if (key == 'h') {
    println("pressed h");
    // set hq the home quaternion as the quatnion conjugate coming from the sensor fusion
    hq = quatConjugate(q);
  else if (key == 'n') {
    println("pressed n");
    hq = null;
// See Sebastian O.H. Madwick report
// "An efficient orientation filter for inertial and intertial/magnetic sensor arrays" Chapter 2 Quaternion representation
void quaternionToEuler(float [] q, float [] euler) {
  euler[0] = atan2(2 * q[1] * q[2] - 2 * q[0] * q[3], 2 * q[0]*q[0] + 2 * q[1] * q[1] - 1); // psi
  euler[1] = -asin(2 * q[1] * q[3] + 2 * q[0] * q[2]); // theta
  euler[2] = atan2(2 * q[2] * q[3] - 2 * q[0] * q[1], 2 * q[0] * q[0] + 2 * q[3] * q[3] - 1); // phi
float [] quatProd(float [] a, float [] b) {
  float [] q = new float[4];
  q[0] = a[0] * b[0] - a[1] * b[1] - a[2] * b[2] - a[3] * b[3];
  q[1] = a[0] * b[1] + a[1] * b[0] + a[2] * b[3] - a[3] * b[2];
  q[2] = a[0] * b[2] - a[1] * b[3] + a[2] * b[0] + a[3] * b[1];
  q[3] = a[0] * b[3] + a[1] * b[2] - a[2] * b[1] + a[3] * b[0];
  return q;
// returns a quaternion from an axis angle representation
float [] quatAxisAngle(float [] axis, float angle) {
  float halfAngle = angle / 2.0;
  float sinHalfAngle = sin(halfAngle);
  q[0] = cos(halfAngle);
  q[1] = -axis[0] * sinHalfAngle;
  q[2] = -axis[1] * sinHalfAngle;
  q[3] = -axis[2] * sinHalfAngle;
  return q;
// return the quaternion conjugate of quat
float [] quatConjugate(float [] quat) {
  float [] conj = new float[4];
  conj[0] = quat[0];
  conj[1] = -quat[1];
  conj[2] = -quat[2];
  conj[3] = -quat[3];
  return conj;
float channels[5];
I suggest that you read the reference page for analogRead(). It does NOT return a float. Nothing is gained storing the int it returns in a float.
What does this do?
How do you know that there will always be 22 bytes?The 5 channel values are output as strings, with between 1 and 7 characters in each.
serial print float arr, it comes with the library in the tutorial, I would assume it prints the values of the array, since the serial monitor without any of my additional code outputs this: (77917F3F,00000000,00000000,00000000)
that byte reading is for the IMU data only, as you can see it has 4 sets of 8 characters each, in the code it uses a function to convert form hex to dec and each number on each array should be 8 chars long (since it split using the comma)
again this is from the original code, I dont know that there will always be 22 bytes. as you said the 5 additional channels are there so thats why I've come for help
I would assume
You can not ASSUME anything. You have the source code. Look at it.
But, for the sake of argument, let's assume that you are correct. What that function is doing is sending binary data - 4 bytes per float, with ASCII separators between values.
The code you added is NOT sending binary data. It is converting each float (that shouldn't be a float) to a string, and sending the string.
The original code is sending 16 bytes plus a leading character plus 3 separators plus a trailing character plus (possibly) carriage return and/or line feed. That is 22 or 23 bytes.
You have not adjusted the size to hold the additional data you are sending, which is not of fixed size.
You would be better off sending the original 4 values plus the 5 new values in one call to that function. Figure out, if you send data that way, how many bytes you are actually sending (5 more per additional element in the array, for a total of 25 more).
Then, modify the Processing code to read a longer stream in exactly the same way it read the original stream, using larger arrays to hold the added data.
