For my master finals I am planning to make some kind of interactive sculptures. One of them is supposed to work with the kinect sensor using the body movements to manipulate the sculpture. I have been trying some examples that I found in some books and I found one in particular that could be adapted to my work. The example I am attaching is from the chapter 6 in the book "Arduino & Kinect Projects" from Enrique Ramos Melgar and Ciriaco Castro Diez.
It is a puppet that can be manipulated via internet with the kinect sending signal through Arduino to the servos attached to each joint .
My question might be quite stupid but I have no idea how to do this and have tried everything I could. I just want it to do the same but over serial communication and not over a server/client. That the user stands in front of the sculpture and the servos move with their body movement in front of them and not somewhere else.
That isn't a question. That is a statement.
The ino file you posted gets data from the serial port. I don't understand what the problem is.
PaulS:
I am sorry if I was not clear enough.
I need to make this .ino file talk to the processing file to be interpreted by the Kinect Sensor. In the book I mentioned the example is made through network communication which I want to omit and just do it by normal serial communication. And that is what I don't know how to do.
