Info about the projcet:
I'm interfering with the arduino over a serial port system. What its supposed to do is to change the output from when I pressed Q and W to high and low, respectally. Beside that I want it to play different notes on the keys from A->K. Theres not much going into it. It's one of my first real "on my own builds" and I had only a few random parts lying around. What I used in this was:
- A mini speaker
- A 470 resistor hooked to pin 9
- A 1k resistor hooked to pin 3
- An arduino :smiley
The problem in a nutshell:
So basicly when I use the arduinos serial and put my commands into it, my mini speaker works perfectly. So I won't be sending picture of the circuit, nor do I have anything that can take pictures. Beside that the problem is more or less that when I input the commands into Arduinos serial it produce clear sound, thus when I run my program over processing and hits my keys it fucks up.
The power is lower so is the sound. I get scattering sounds and it just sounds awful.
The Codes:
Arduino part:
beep(speakerPin,2093,tempo); //C: play the note C (C7 from the chart linked to above) for tempoms
beep(speakerPin,2349,tempo); //D
beep(speakerPin,2637,tempo); //E
beep(speakerPin,2793,tempo); //F
beep(speakerPin,3136,tempo); //G
beep(speakerPin,3520,tempo); //A
beep(speakerPin,3951,tempo); //B
beep(speakerPin,4186,tempo); //C
int High = 9;
int Low = 3;
int Volume = 9;
int LoopTime = 379*2;
void beep (int speakerPin, int Hertz,char Note) // the sound producing function
int x = 0;
Serial.println("Beep was called by the note of:");
long delayAmount = (long)(1000000/Hertz);
Serial.println(delayAmount);
do{
digitalWrite(speakerPin,HIGH);
delayMicroseconds(delayAmount);
digitalWrite(speakerPin,LOW);
x = x+1;
while (Serial.read()!='R');
Serial.println("I was released");
pinMode(High, OUTPUT);
pinMode(Low, OUTPUT);
//Testing sound
analogWrite(Volume, 255);
void loop() // run over and over again
while(Serial.available() == 0);
switch(char val = Serial.read()){
case 'H':
Volume = 9;
Serial.println("Volume was set to high");
case 'L':
Volume = 3;
Serial.println("Volume was set to low");
case 'C':
beep(Volume,2093,'C');
case 'D':
beep(Volume,2349,'D');
case 'E':
Serial.println("PLAYING E");
Serial.println(Volume);
beep(Volume,2637,'E');
case 'F':
beep(Volume,2793,'F');
case 'G':
beep(Volume,3136,'G');
case 'c':
beep(Volume,4186,'c');
case 'A':
beep(Volume,3520,'A');
case 'B':
beep(Volume,3951,'B');
Processing part:
import processing.serial.*;
Serial port;
int HighVol = 8;
int LowVol = 3;
int volume = LowVol;
size(100, 400);
port = new Serial(this, "COM8", 9600);
port.bufferUntil('\n');
void draw() {
if (keyPressed) {
switch(key) {
case 'q':
port.write("L");
case 'w':
port.write("H");
case 'a':
port.write("C");
case 's':
port.write("D");
case 'd':
port.write("E");
case 'f':
port.write("F");
case 'g':
port.write("G");
case 'h':
port.write("A");
case 'j':
port.write("B");
case 'k':
port.write("c");
port.write("R");
