Arduino & Processing Serial Communcation Problem
Hi All,
I am trying the following simple code to let processing and arduino communicate via serial port.
However it doesn’t work.
The RX LED on the Arduino board keep flashing, but the LED won’t light ON.
If I use the serial monitor to insert the character H, the LED can be ON.
Another solution is, when I added a ‘delay(1000)’ in the Arduino code, the LED can be ON as well.
I suppose the ‘delay(1000)’ is unnecessary, but it make the code work.
Does anyone know what is the problem?
char val = 0;
  pinMode(12, OUTPUT);
  // read data if available
  if (Serial.available()) {
    val = Serial.read(); // read one byte
    //Serial.flush(); // flush other data
  // Turn LED on if H was received
  if (val == 'H') {
    digitalWrite(12, HIGH);
    digitalWrite(12, LOW);
import processing.serial.*;
Serial myPort;
int val;
  size(200, 200);
  // the name of port connecting the arduino
  String portName = Serial.list()[0];
  myPort = new Serial(this, portName, 9600);
void draw() {
  background(255);
  // If mouse is over square
  if (mouseX >= 50 && mouseX <= 150 &&
      mouseY >= 50 && mouseY <= 150)
    fill(204); // change color and
    myPort.write('H'); // send an H to Arduino
  else // If mouse is not over square,
    fill(0); // change color and
    myPort.write('L'); // send an L otherwise
  // Draw a square
  rect(50, 50, 100, 100);
  //delay(1000);
Change the processing code so you don't send the L it sounds like your buffer is being filled up with Ls
You might want to send one L when the mouse is not over the square, and one H when it is over the square, not send L or H as fast as possible.
Is there any problem if I send the L or H as fast as possible?
MY concept is
Processing send LLLLLLLLLL…-> Arduino buffer store [L]
After mouse trigger
Processing send HHHHHHHH…-> Arduino buffer store
And then the LED being turn on because it reads ‘H’, but it seems not work in realality.
It only work when I do in following way with delay 1000…
Processing send L(delay1000)L(delay1000)L(delay1000)L…-> Arduino buffer store [L]
After mouse trigger
Processing send H(delay1000)H(delay1000)H(delay1000)H…-> Arduino buffer store
LED turn ON
Is there anything wrong?
Get rid of that Serial.list()[0] line (who started that nonsense, anyway?). Replace portName with "COM3" or whatever port your Arduino uses. This works on my computer:
  myPort = new Serial(this, "COM6", 9600);
How about putting a few print statements in the Arduino program and have your processing expect them and echo them perhaps to console? Then you'll know what's going on.
BTW, by processing do you mean a PC program like you would write in C++, Java, Perl or Basic even?
Or is there a language called Processing? And if so, what's the draw from it, the good parts?
JavaMan:
Serial.list()[0] works on my computer, using a different operating system. There's no such thing as "COM6" on my computer. So why should OP change to using something that has to be changed for every computer he's on, rather than something that's even cross-kernel compatible?
Note that on unix environments, the location of the com port can change if you unplug-and-replug a device too quickly -- so the arduino may be on /dev/ttyACM0 and when unplug it and plug it back in, it'll be on /dev/ttyACM1. I don't want to have to figure out where it is and change the program accordingly when the program can do it itself.
Yes. It's what the arduino IDE is based off of. Many people use them together.
You're not using an Apple, are you? (who started that nonsense, anyway?) ]:smiley:
OK, good point, but remember Serial.list()[0] did not work for the OP. Why not? There are no other issues with the posted code, because after changing that line I ran it and it worked fine.
GoForSmoke:
I will try it later, but my Arduino seems never detect the serial data bcoz I tried to add LED ON statement right inside this condition
It never jump into this condition, but I see the RX LED light keep flashing......
denyip:
Is there any problem if I send the L or H as fast as ..........
It only work when I do in following way with delay 1000..
No helping some people is there?
WizenedEE:
The language we use to program these AVR's is Gnu C++.
Want the homepage? The site has loads of good docs for the libraries.
http://www.nongnu.org/avr-libc/
At first I thought it might be some kind of lab language. But somehow I don't see using this:
to program an Arduino unless the Arduino has a graphics shield.
Arduino IDE has no graphics I ever saw, and I read the docs!
From the Wiki, it's an extended Java which is kind of like a loose C/C++ -- just different enough to screw you up going back and forth.
A lot of times the context I see used with the word processing could describe interaction with any automatic program at the PC end.
denyip:
Maybe try this in setup(). If the serial TX connect is right, the Arduino will announce itself.
  Serial.println("\n\nSerial Tested One Way\n");
@ op:
do what grumpy mike said. the problem with sending serial data as fast as possible is that if the receiving end cannot keep up with the speed you are sending at, things go haywire. what I usually do is have bidirectional communication going on, with the receiving end sending out a bite as soon as its ready for new data. There is example code for that both in the arduino as in the processing IDE. You will want to use this function http://processing.org/reference/libraries/serial/serialEvent_.html
Alternately make sure that you only send the char once, when you move on or off the square...
You do NOT use processing to program an Arduino.
Processing is a language run on the host computer that you can use to communicate with an arduino. As such Processing has access to all the computers resources, like graphics display, file handling, sound players and so on. This allows the arduino to control these.
The two systems communicate with each other using a serial port.
Note that when Processing opens up a serial port this resets the Arduino smothers is a few seconds delay before the arduino is ready to talk. The delay() function in Processing is not the same as in the Arduino and will not work in the same way, so it can't be used to add a delay after the serial port is open.
Finally make it work as advised by above ppl send the byte one by one, but not send as fast as, as much as possible.
My Arduino evan can't detect there is data flow in by this way. It seems it's a limitation of arduino board.
No. It is likely an issue with needing to convert each value to a string, send the string, and then convert it back.
There are ways to send binary data, so the value to string and string to value conversions are not required. Much faster that way.
Of course, seeing the code that you ended up with would be important in order to suggest real improvements.
