arduino program output issue
i am using this code in my arduino as sketch but on serial monitor the the output is
Goodnight moon!
mySerial.println(“Hello, world?”); output not showing .
pls help me
my code is below.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println(“Goodnight moon!”);
// set the data rate for the SoftwareSerial port
mySerial.begin(115200);
void loop() { // run over and over
if (mySerial.available()) {
Serial.write(mySerial.read());
if (Serial.available()) {
mySerial.write(Serial.read());
How many Arduinos are you using, which boards and how are they connected ?
That baud rate for SoftwareSerial is too high. Try 9600.
And address Bob’s questions regarding your setup. :slight_smile:
Edit: Oh, and also you should always post your code between code tags. They can be generated using the </> button in the post or “Reply” windows, or manually typed like this:-
[code]Place your code here[/code]``It will appear in a block like this
Serial.println("Goodnight moon!");
Is sent out on the programming port that your monitor is connected to.
  mySerial.println("Hello, world?");
Is sent out the following port;
Defines the port which I don't think you are connected to with your monitor.
Tom... :)
Hi ,
  1. Board - Arduino Uno
2 . I worked with baud rate then problem is at is.
Thanks all for your response.
  1. i connected with VGA port to Arduino.
The code is designed to work with two Arduinos connected back to back to demonstrate the use of SoftSerial in communicating with one another.
