arduino program to measure time interval between two peaks
Hai friends,
I am working on PPG so as a part of it I need to find the interval between the sinusoidal waveform.
I have been trying to find the time intervals between peaks of sinusoidal wave and the code is provided below, when I run the code it shows the value as 4294925424. Someone please sort the mistake in my code!!!
testedarduinocodeforppg.ino (1.03 KB)
int count = 0; Should be unsigned, maybe even unsigned long .
Hello Larry,
I have changed the count to unsigned and even unsigned long but it shows the same (2^32)-1 value.
Prior I wish to know whether my program logic correct.
Thank you Larry,
Is the sine wave offset so it stays between 0 and 5 volts? .
To Larry:
Yes I provided the offset and it stays between 0 to 5v
  • Put some in comments so we can following your thinking.
  • Press CTRL T to format your code.
  • To get help, you must show us your complete sketch. Attach your code using the </> icon on the left side of the posting menu.
EDIT:
What is the frequency range?
You know this would be so much simpler if you squared the sine wave off and did this digitally :wink:
else if (now == prev)
this may never happen or take a very long time.
Larry I didn't get you so I have posted the whole code, sorry if it annoys you and the frequency ranges from 0.5-5Hz.
int ain = A2;            //Analog pin to read signals
int now = 0;            //checks current status of analog pin 2
int prev= 0;            //checks previous state
unsigned long count = 0;
unsigned long firstpulse = 0;
unsigned long totaltime = 0;
unsigned long lastpulse = 0;
  pinMode(ain,INPUT);
  now = analogRead(ain);
  delay(100);
  if(now!=prev)
    if( now >= prev)
       prev = now;
       Serial.println("Current value is greater than previous value");
    if(count == 0)
      firstpulse = millis();
      count += 1;
    else if(count >= 1)
      count += 1;
      lastpulse = millis();
    Serial.println(lastpulse - firstpulse);
    Serial.print("----->Count:");
    Serial.print(count);
    Serial.println("--------------");
    firstpulse = lastpulse;
    lastpulse = 0;
    count = 0;
Is there a reason why you are doing the calculation using an analog input. You could square the waveform and do the calculation on a digital input. Which is easier.
Comments help us follow your thought process, example:
//have we reached a maximum level? if( now >= prev) {
For two analog readings to be the same, may take a very long time as there is input noise, time delays in your program and input fluctuations. (you may miss several/numerous cycles til you reach the same levels)
What are you thinking is happening here? else if (now == prev)
:sleeping: Time
This isn’t what you want but might give you some ideas:
int analogInput = A0;
int thisReading = 0;
byte hysteresis = 10;
byte flag = 0;
unsigned long startMicros = 0;
unsigned long lastPeakMicros = 0;
  pinMode(analogInput,INPUT);
  //Debug
  pinMode(13,OUTPUT);
} //END of setup()
  thisReading = analogRead(analogInput);
  //Debug
  if(thisReading >= 512 + hysteresis)
    digitalWrite(13,LOW); //Turn on LED
  else if(thisReading <= 512 - hysteresis)
    digitalWrite(13,HIGH); //Turn off LED
  //End of debug
  //have we gone above 512
  if(flag == 0 && thisReading >= 512 + hysteresis)
    flag = 1;
    //record this time
    startMicros = micros();
  //have we gone below 512
  if(flag == 1 && thisReading < 512 - hysteresis)
    //Print the time it took form 512+hys to 512-hys
    Serial.print("It took " );
    Serial.print(micros() - startMicros);
    Serial.println(" micro seconds for 1/2 cycle." );
    flag = 0;
} //END of loop()
If the sine wave signal is regular (ie not frequency modulated) and you are simply trying to determine the frequency, you can simply do this with a digital pin and an interrupt.
The interrupt service routine, which is triggered by a status change on the digital pin, simply counts the number of times it is triggered (once per zero crossing) in a unit time.
As is clear also from Larryd’s code, your use of millis() (milliseconds) to measure time intervals in a 5KHz signal is too rough to yield usable results.
