Hi all, I am fooling around with a program I found on an Arduino site. I would like to make a indoor air quality monitor for my Arduino uno. I copied a program that looked simple enough with little hardware to purchase. When I went to compile the program after installing it I got an error wherever a line had this in it
cipsend += connectionId; I don't know if I am missing a library or what. If you can, please help. Thanks
We’ll never know until you post your COMPLETE code within code tags
I think you have ESP32 code.
Look for Arduino code.
https://docs.espressif.com/projects/esp-at/en/latest/esp32/AT_Command_Set/TCP-IP_AT_Commands.html
type or paste code [code]
#include <SoftwareSerialTX.h>
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
#include <MQ135.h>
#define DEBUG true
SoftwareSerial esp8266(9,10);
const int sensorPin= 0;
int air_quality;
LiquidCrystal lcd(12,11, 5, 4, 3, 2);
pinMode(8, OUTPUT);
lcd.begin(16,2);
lcd.setCursor (0,0);
lcd.print ("circuitdigest ");
lcd.setCursor (0,1);
lcd.print ("Sensor Warming ");
esp8266.begin(115200);
sendData("AT+RST\r\n",2000,DEBUG);
sendData("AT+CWMODE=2\r\n",1000,DEBUG);
sendData("AT+CIFSR\r\n",1000,DEBUG);
sendData("AT+CIPMUAIR_QUALITY=1\r\n",1000,DEBUG);
sendData("AT+CIPSERVER=1,80\r\n",1000,DEBUG);
pinMode(sensorPin, INPUT);
lcd.clear();
MQ135 gasSensor = MQ135(A0);
float air_quality = gasSensor.getPPM();
if(esp8266.available())
if(esp8266.find("+IPD,"))
int connectionId = esp8266.read()-48; /*
String webpage = "<h1>IOT Air Pollution Monitoring System</h1>";
webpage += "<p><h2>";
webpage+= " Air Quality is ";
webpage+= air_quality;
webpage+=" PPM";
webpage += "<p>";
if (air_quality<=1000)
webpage+= "Fresh Air";
else if(air_quality<=2000 && air_quality>=1000)
webpage += "Poor Air";
else if (air_quality>=2000 )
webpage+= "Danger! Move to Fresh Air";
webpage += "</h2></p><body>";
String cipSend = "AT+CIPSEND=";
cipSend += connectionId;
cipSend += ",";
cipSend +=webpage.length();
cipSend +="\r\n";
sendData(cipSend,1000,DEBUG);
sendData(webpage,1000,DEBUG);
cipSend += ",";
cipSend +="\r\n";
String closeCommand = "AT+CIPCLOSE=";
closeCommand+=connectionId;
closeCommand+="\r\n";
sendData(closeCommand,3000,DEBUG);
lcd.setCursor (0, 0);
lcd.print ("Air Quality is ");
lcd.print (air_quality);
lcd.print (" PPM ");
lcd.print("Fresh Air");
digitalWrite(8, LOW);
else if( air_quality>=1000 && air_quality<=2000 )
lcd.print("Poor Air, Open Windows");
lcd.print("Danger! Move to Fresh Air");
digitalWrite(8, HIGH);
lcd.scrollDisplayLeft();
String sendData(String command, const int timeout, boolean debug)
String response = "";
esp8266.print(command);
long int time = millis();
while( (time+timeout) > millis())
while(esp8266.available())
char c = esp8266.read();
response+=c;
if(debug)
Serial.print(response);
return response;
[/code]
Are you making an ESP8266 communicate with an Arduino Uno?
Why is 75% of your code commented-out?
Draw a wiring diagram to show your intent.
I don't know if it changed at your end but what I show what I posted nothing is commented out. The only lines I commented out to get it to compile was the lines I stated at first. CipSend += connectionId; I recommended before sending to the forum.
Your post #4 clearly shows the comment mark. Why are you not looking at your own code?
SoftwareSerial is unlikely to work or be reliable at 115200 bps
