Hello everyone i make a simple code
i make that led turns on by push buttom
and i wanna make more like this in one program for another channels
There is a code please help me
**int J1 = A0; **
**int O1 = 13; ** int val = 0; int lightON = 0; int pushed = 0;
const int J1 = A0;
const int O1 = 13;
int val = 0;
int lightON = 0;
int pushed = 0;
pinMode(J1, INPUT_PULLUP);
pinMode(O1, OUTPUT);
digitalWrite(O1, HIGH);
val = digitalRead(J1);
if (val == HIGH && lightON == LOW)
pushed = 1 - pushed;
delay(100);
lightON = val;
if (pushed == HIGH)
Serial.println("Light ON");
digitalWrite(O1, LOW);
Serial.println("Light OFF");
So 'J1' is a button and you want to toggle the LED (O1) when the button is pressed? And you watn to have that happen for multiple buttons/LEDs?
Here is a sketch I wrote for detecting state changes and debouncing buttons. Perhaps it will be handy as an example.
const byte ButtonCount = 3;
const byte ButtonPins[ButtonCount] = {2, 3, 4};
const unsigned long DebounceTime = 30;
boolean ButtonWasPressed[ButtonCount]; // Defaults to 'false'
boolean ButtonChangedState[ButtonCount]; // Defaults to 'false'
unsigned long ButtonStateChangeTime = 0; // Debounce timer common to all buttons
pinMode(LED_BUILTIN, OUTPUT);
for (byte i = 0; i < ButtonCount; i++)
pinMode (ButtonPins[i], INPUT_PULLUP); // Button between Pin and Ground
checkButtons();
void checkButtons()
unsigned long currentTime = millis();
// Update the buttons
boolean buttonIsPressed = digitalRead(ButtonPins[i]) == LOW; // Active LOW
ButtonChangedState[i] = false;
// Check for button state change and do debounce
if (buttonIsPressed != ButtonWasPressed[i] &&
currentTime - ButtonStateChangeTime > DebounceTime)
// Button state has changed
ButtonStateChangeTime = currentTime;
ButtonChangedState[i] = true;
ButtonWasPressed[i] = buttonIsPressed;
// Act on the the buttons
if (ButtonChangedState[i])
if (ButtonWasPressed[i])
// Button was just pressed
// Button was just released
