Arduino programmer and Adafruit Trinket
The USBtiny driver successfully installed in my Win10 system and the USBtiny device shows up in the device manager. The additional boards link for the Adafruit Trinket pro 12MHz/3V was installed in preferences. The Adafruit Trinket Pro 3V 12MHz/USB is selected. The programmer is set to USBtinyISP. The example program BLINK is loaded. .
The following error occurs when trying to upload.
Sketch uses 1,078 bytes (3%) of program storage space. Maximum is 28,672 bytes.
Global variables use 9 bytes of dynamic memory.
avrdude: verification error, first mismatch at byte 0x0387
0x5f != 0x4f
avrdude: verification error; content mismatch
Any ideas on what's wrong?
Being new to the forum and Arduinos (I am more familiar with PIC processors), my first guess would be a problem with the chip (try a second board if you have one). The difference between 0x5f and 0x4f is one bit and most of the flash memory I am familiar with erases to all 1's - from that error, it looks like one bit did not get set to a 0 when it should have been. Maybe others have a better idea - it would be nice if you had a second board to try it with.
mikey
Do you have a Trinket or a Trinket Pro? Those are 2 different boards and you mention one in the title and a different one in the body of your message.
