I'm encountering difficulties with programming and integrating hardware using Arduino. Despite following tutorials and troubleshooting, I'm facing issues with code execution and hardware connectivity. Has anyone else experienced similar challenges? What resources or troubleshooting steps can help improve Arduino project development?
Your topic has been moved. Please do not post in "Uncategorized"; see the sticky topics in Uncategorized - Arduino Forum.
Welcome to the forum
You started a topic in the Uncategorised category of the forum when its description explicitly tells you not to
Your topic has been moved to a relevant category. Please be careful in future when deciding where to start new topics
probably start by the basics:
- follow a C++ tutorial to make sure you master the programming language
- invest time to understand the basics of electronics and simple components (resistors, capacitor, transistors, power supplies,...) and the laws behind them.
- play with simple arduino tutorials, starting by blinking a LED and getting deeper
Then when you master this, you can build up on solid fundations and tackle more difficult projects
This is normal and everyone from beginner to expert faces similar challenges.
As a beginner, you attempt projects that are beginner level of difficulty. You encounter problems which seem large at first but you grow your skills and experience and eventually you are ready for intermediate level projects.
As an expert, you attempt expert level projects. You encounter much more challenging problems that would be impossible to solve as a beginner, but the confidence, knowledge and experience that you have built up enables you to overcome them.
Whatever your level of experience, if you found every project to be easy and contain no challenges or opportunities to learn, that would be very boring!
Start simple , flash the on board LED , change rate of flashing …. Flash an externally mounted led ..and so on .
Switch the led on and off with a push button .
Lots of examples in file /examples .
Do that stuff before wondering why you Nuclear power station controller isn’t working .
Let us know specific issues , most of which , at this stage Mr Google can answer .
Post your code and a schematic/wiring diagram and maybe we can help
As a general rule, don’t learn by using GPT, because you’re not learning, but you’re likely teaching GPT bad style and habits.
