Arduino Programming Problem
I am trying to program two actuators using an X and Y analog joystick. Everything compiles when i cut out either top (actuator1) or bottom (actuator2) section in the void loop! What am i doing wrong, so it compiles?
const int feedback = A0; //potentiometer from actuator
const int pot = A1; //pot from throttle
const int feedback2 = A2; //potentiometer from actuator
const int pot2 = A3; //pot from throttle
const int enable = 4;
const int PWMA = 3;
const int PWMB = 5;
const int enable2 = 7;
const int PWMC = 6;
const int PWMD = 9;
int actMax = 760;
int actMin = 250;//positions of actuator
int actMax2 = 760;
int actMin2 = 250;//positions of actuator
int potMin = 0;
int potMax = 1023;
int potMin2 = 0;
int potMax2 = 1023;
int precision = 2;//how close to final value to get
int checkingInterval = 50;//how often position is checked (milliseconds)
int precision2 = 2;//how close to final value to get
int checkingInterval2 = 50;//how often position is checked (milliseconds)
int rawcurrentPosition = 0;
int currentPosition = 0;
int rawdestination = 0;
int destination = 0;
int difference = 0;//values for knowing location
int rawcurrentPosition2 = 0;
int currentPosition2 = 0;
int rawdestination2 = 0;
int destination2 = 0;
int difference2 = 0;//values for knowing location
 pinMode(feedback, INPUT);//feedback from actuator
 pinMode(pot, INPUT);//feedback from potentiometer
 pinMode(feedback2, INPUT);//feedback from actuator
 pinMode(pot2, INPUT);//feedback from potentiometer
 pinMode(enable, OUTPUT);
 pinMode(PWMA, OUTPUT);
 pinMode(PWMB, OUTPUT);//three pins for MegaMoto
 pinMode(enable2, OUTPUT);
 pinMode(PWMC, OUTPUT);
 pinMode(PWMD, OUTPUT);//three pins for MegaMoto
 digitalWrite(enable,HIGH);
 digitalWrite(enable2,HIGH);
void loop()   //--------------------------------------------------------------------------------------------------------
   destination = getDestination();
   currentPosition = analogRead(feedback);//check where you are
   Serial.print("Position    ");
   Serial.println(analogRead(feedback));
   difference = destination - currentPosition;//find out how far you are from the destination
   if (currentPosition > destination) pullActuatorUntilStop(destination);// choose what action to take
   else if (currentPosition < destination) pushActuatorUntilStop(destination);
   else if (difference < precision && difference > -precision) stopActuator();
}//end void loop
int getDestination()
   rawdestination = analogRead(pot);//read the potentiometer to get the destination
   destination = map(rawdestination, potMin,potMax,actMin,actMax);//convert the potentiometer feedback to match the actuator
   return(destination);
}//end getDestination
void pushActuatorUntilStop(int destination)
 int temp = analogRead(feedback);
 difference = destination - temp;//check difference to see if continue moving, or stop
 while (difference > precision || difference < -precision)
   temp = analogRead(feedback); //continue checking difference
   pushActuator();
 }//end while
 delay(25);
 stopActuator();
}//end pushActuatorUntilStop
void pullActuatorUntilStop(int destination)
 int temp = analogRead(feedback); //check difference to see if continue moving, or stop
   pullActuator();
 }//end while
 delay(25);
 stopActuator();
}//end pullActuatorUntilStop
void stopActuator()
 analogWrite(PWMA,0);
 analogWrite(PWMB,0);
}//end stopActuator
void pushActuator()
 analogWrite(PWMB,255);
}//end pushActuator
void pullActuator()
 analogWrite(PWMA,255);
}//end pullActuator
//addon secound acuator //---------------------------------------------------------------------------------------------
   destination2 = getDestination2();
   currentPosition2 = analogRead(feedback2);//check where you are
   Serial.print("Position2    ");
   Serial.println(analogRead(feedback2));
   difference2 = destination2 - currentPosition2;//find out how far you are from the destination
   if (currentPosition2 > destination2) pullActuatorUntilStop2(destination2);// choose what action to take
   else if (currentPosition2 < destination2) pushActuatorUntilStop2(destination2);
   else if (difference2 < precision2 && difference2 > -precision2) stopActuator2();
}//end void loop
int getDestination2()
   rawdestination2 = analogRead(pot2);//read the potentiometer to get the destination
   destination2 = map(rawdestination2, potMin2,potMax2,actMin2,actMax2);//convert the potentiometer feedback to match the actuator
   return(destination2);
}//end getDestination2
void pushActuatorUntilStop2(int destination2)
 int temp2 = analogRead(feedback2);
 difference2 = destination2 - temp2;//check difference to see if continue moving, or stop
 while (difference2 > precision2 || difference2 < -precision2)
   temp2 = analogRead(feedback2); //continue checking difference
   pushActuator2();
 }//end while
 delay(25);
 stopActuator2();
}//end pushActuatorUntilStop2
void pullActuatorUntilStop2(int destination2)
 int temp2 = analogRead(feedback2); //check difference to see if continue moving, or stop
   pullActuator2();
 }//end while
 delay(25);
 stopActuator2();
}//end pullActuatorUntilStop2
void stopActuator2()
 analogWrite(PWMC,0);
 analogWrite(PWMD,0);
}//end stopActuator2
void pushActuator2()
 analogWrite(PWMD,255);
}//end pushActuator2
void pullActuator2()
 analogWrite(PWMC,255);
}//end pullActuator2
Where are your code tags? Please edit your post.
What are your errors? Copy and paste your error window.
I bet the problem lies at line 131 due to the lack of a declaration for the function. I notice the comment in line 140 says "end of void loop". One one void loop() per program. Looks like a syntax error and an architecture issue.
Arduino: 1.8.2 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
sketch_aug01b:141: error: expected unqualified-id before '{' token
exit status 1
option enabled in File -> Preferences.
You have all the information you need to fix the program now. If you have another issue, repost the updated program and errors.
https://www.actuatorzone.com/blog/helpful-advice-tips/position-control-of-a-linear-electric-actuator-w-analog-sensor/
The link above is where i got the code from. Trying to add a secound actuator to the coding. It compiles the coding everytime independently on each actuator BUT as soon as i stitch them together is where i get the problem.
I tried different ways of stitching together but i had no sucess.
